Old 03-07-2012, 05:32 PM   #1
steel stud interior wall - 16 foot high
how do I start? I am familiar with building wood frame walls and tipping them up. Thanks.
kris h is offline   Reply With Quote
Old 03-07-2012, 06:29 PM   #2
snap your line along the floor,
attach track to floor(wood screw for wood, tapcon for concrete, or powder hilti/ramset gun),
measure your height on either end and cut your 2 end studs a little short like 1/4-1/2",
screw studs to bottom track.
now slide the top track over the studs and screw them to the top track,
throw a level on each stud
attach top track to roof
cut and screw in other studs.
princelake is offline   Reply With Quote
Old 03-07-2012, 07:44 PM   #3
Super Moderator
Also add fire blocking to meet your local code.
Old 03-07-2012, 11:13 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
for steel stud, all studs get cut 1/2" short for fire code, if a fire does occur the steel must be allowed space to expand with the extra heat
for attaching hte top plate. first rent a laser level that shoots a plumb line.. strike the line on the floor and ceiling, attach the track to the floor and ceiling. now fill the studs in.. plumb the first one and mark your 16" on centres from that. .unlike with wood framing where you offset the stud by 3/4" simply mark 16, 32, 48 and center the stud on the mark. steel stud's arent 1 -1/2 their closer to 1 1/4"
woodworkbykirk is offline   Reply With Quote
Old 03-09-2012, 10:08 AM   #5
Anyone care to confirm size and spacing ?
Marvel is offline   Reply With Quote
Old 03-09-2012, 09:00 PM   #6
i didnt know the 1/2" was for fire code, it was just the way i was shown how to do it. and yes a laser level does wonders i just assumed the average guy wouldnt have one. and what are you looking for? actual size of the studs?
Old 03-09-2012, 09:42 PM   #7
retired union carpenter
Send a message via Yahoo to coupe
it would help to know what this wall will bee supporting as well as what is supporting the wall?
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 03-10-2012, 11:05 PM   #8
you've never said! what are you attaching wall to? ceiling and floor?
Old 03-11-2012, 05:19 PM   #9
I'm on the same boat, I want to learn how to install drywall for my new house. Since I live in Brazil, people here uses primarily brick for walls, and drywall is just getting its space here in the last decades. I quite new to DIY in house construction, I worked mostly with wood, electricity and electronics.
One thing that is troubling me is how to fasten the runners, do I have to use a powder fastener or can I use a regular drill, screw and plug for concrete floors (in Brazil that is the norm, no wood floor here).
Also, how to fix the top runners in cases here I have a concrete beam on the way? Do I just fix it over (actually below) the beam?
zhouluyi is offline   Reply With Quote
Old 03-11-2012, 05:35 PM   #10
powder gun from like hilti or ramset and blast it to the track to the floor is the quickest. you can tapcon it but it takes alot longer. you can shoot the ramset into steel, the nail will basically weld itself to the steel.
Old 03-11-2012, 06:46 PM   #11
the only way this wall can be supporting anything is if its heavy gauge structural steel.. i highly doubt that it is... prob just light gauge which means its nothing more than a curtain wall
Old 03-11-2012, 08:14 PM   #12
The problem with using a powder gun is that it requires a special license to use, and besides that it's very hard to find a gun and the pins for it in my area. That's why I want to know if it is doable with other techniques.
Old 03-11-2012, 08:25 PM   #13
who says you need a special license for powder gun
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 03-11-2012, 08:31 PM   #14
In Brazil you need a license to work with it (and even to buy the .22 cartridges), at least that's what I heard... also, a gun cost about 2500 dollars here. Kind of expensive for a one-time DIY use (I don't plan on change the wall of my house)...
Old 03-11-2012, 08:37 PM   #15
ok got you why do you spell brasil wrong if you are from there
there are also other ways gas powered made by hilti, track fast,and powers fasteners
there is also another using nitro cells called nitro set which works great in real hard concrete
2 foot high cinder retaining wall, foundation needed? average_male Landscaping & Lawn Care 8 06-01-2009 06:14 PM
firring out concrete wall for electric and insulation trouble Building & Construction 9 02-04-2009 12:40 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Please, help with sheathing and stud placement Mrmusic Building & Construction 2 09-10-2008 05:52 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
