Steel Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-31-2015, 08:47 PM   #1
Rewards Points: 38
steel stairs
Hello
I am in the middle of my reno and I need to sketch out a stair drawing.
As you guess from title, these are steel.
Are there any web sites to help with a drawing?
I was mounting a three inch slab of wood mounted to a welded.L bracket.
The treads are 9.5 " deep, 36 inch wide by 3" . What size hole to be predrilled in the L bracket
and what size screw or bolt to attach from under side. And how many per side?
Located in Ontario if anyone has building code input.
RJ
Reno_Jayne is offline   Reply With Quote
Old 05-31-2015, 10:11 PM   #2
Rewards Points: 2,210
You will probably need a structural engineer to draw these up.
mae-ling is offline   Reply With Quote
Staining & finishing pine stairs secutanudu Painting 33 10-23-2011 08:15 AM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 06:06 PM
Exterior Stairs to Coach House Need to be Repaired/Replaced. Help Appreciated! 2031pratt Carpentry 9 04-07-2010 02:43 PM
New construction on existing steel building burton Building & Construction 6 03-30-2010 03:22 PM
Steel Posts for Screen Porch dobbsj Building & Construction 2 07-15-2009 05:47 PM
