Steel Replacement Girder - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 03:10 PM   #1
Hello all, after reading the threads here and elsewhere I have been able to obtain really helpful information. My question is more of a request for someone to check my calculations. If you are an engineer, or have experience calculating beam sizes please let me know what you think. I understand the well- intentioned "hire a structural engineer comments", but please do not add these to the thread, I have already spoken with an engineer, and my plan is based on his advice.
The beam being replaced is made up of 3 old 2x10 (real 2x10's, oak, from 100 years ago), making up a basement girder which holds up three floors. It is 21 ft long from wall to wall of the foundation, and appears to have been reinforced with relatively new vertical 4x6 post and a telescoping post, but is sagging and has been destabilized by termites.
My question, will a 4 inch wide W12x16, supported at 7 ft intervals provide an adequate replacement? According to my calculations this is stronger than the present beam, but I would like someone else to check my calculations since statics was not my best class.
Thank you.
Regards,
D.
DsMoneypit is offline   Reply With Quote
Old 06-11-2012, 03:13 PM   #2
Rewards Points: 502
Post your calcs, then, so we can check them.
tony.g is offline   Reply With Quote
Old 06-11-2012, 08:10 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
what did your engineer say?????????
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-11-2012, 08:13 PM   #4
Framing Contractor
Thank you.
Regards,
D.
You spoke to an engineer. What's the problem? How come he's not answering your question?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-11-2012, 09:59 PM   #5
AHH, SPANS!!!
Rewards Points: 1,166
maybe the engineer was not paid and only gave partial free advice
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
AndyGump (06-12-2012)
Old 06-11-2012, 10:32 PM   #6
Joe and Hand: unhelpful. If you can't contribute useful information please don't reply.
Tony, my back of the envelope calc went something like this
Present wood beam
I= bh^3/12=500
s=bh^2/6=100
W12x16 steel I beam I=103, s=17.1 from:
http://www.toolbase.org/PDF/DesignGu...SpanTables.pdf
Steel approx 30x stronger than wood in bending and tensile strength (36k psi vs 1-8k psi)
Hence my ibeam choice, I>= 500/30 and s >=100/30. However, the above link places the max span at 4.1 ft for Mc in the charts (largest moment), so I'm thinking my material property approximation is incorrect enough to make my beam choice too weak, or at least perhaps at my 7ft support length, since it has 3 floors above it.
Old 06-12-2012, 12:02 AM   #7
Missouri Bound's Avatar
You probably won't think my post is useful either, but why in the would you talk to an engineer and THEN go to a DIY site? You have already done the calculations, checked with a professional, right? Are you looking for a pat on the back or what?
Do you want it your way or the right way?
Old 06-12-2012, 12:24 AM   #8
Rewards Points: 150
Present wood beam
I= bh^3/12=500
s=bh^2/6=100
FAIL
You are miss using the tables. Lc is the maximum length of an unsupported beam (i.e. cantilever). Using the worst case scenario table, a W12x16 beam supportted every 7 feet can support joist spanning a total of 48 feet. These tables assume that the beam is not supporting any roof load, which is not necessarily valid for a 100 year old house.
Following the tradition of this group, you have shown sufficient lack of knowledge that I would recommend you hire a professional. In this case the savings in the cost of the beam will more than pay for the cost of an SE.
goosebarry is offline   Reply With Quote
Old 06-12-2012, 12:43 AM   #9
Perhaps you are assuming by "speaking" that my combination of ibeam and column support distances have been verified, which is not the case. We spoke about my plan generally but the approximation aspect was my idea. I'm not sure i understand the animosity toward a guy who simply wants a second opinion on a very important structural decision. As my first post states, I only requested someone else examine my analysis. I'm not looking to create friction here, if someone has the knowledge and time, please let me know what you think. Thank you.
Old 06-12-2012, 08:25 AM   #10
Rewards Points: 502
DsMoneypit,
I doubt anyone here is deliberately trying to be unhelpful. Your figures seem OK as far as they go. However, there is far more to this than simply computing 'I' and 's' and checking in charts/tables.
To give one example; steel beams can carry a considerable load, but they are slender can fail by buckling long before they reach maximum load capacity. Could you prove that the load your beam will carry will not exceed
its buckling capacity, or altrnatively could you show that the top flange will be sufficently restrained so as to achieve its maximum capacity?
There are other considerations, such as bearings, and post supports and foundations.
As it is a structural alteration, presumably your local authority will want to see calcs. They will not accept that just because the loads are the same, and steel is 'stronger' than timber, that it will be OK.
Your idea may well work, but it is a case of proving it. I know this is a DIY site, but some aspects are beyond DIY competence, and in these cases the best advice is to get a proper appraisal and supporting figures.
Gopd luck.
Old 06-12-2012, 09:31 AM   #11
Originally Posted by tony.g
DsMoneypit,
Gopd luck.
Thanks Tony. I have thought about the post supports and footers, but I understand your point regarding the difficulty. I will look into the restraining suggestion.
Old 06-12-2012, 12:47 PM   #12
Architect
Rewards Points: 150
I agree with others here. I AM a trained professional, working side-by-side with structural engineers daily, and myself have taken several structural engineering courses as part of my degree requirements, and I wouldn't even try to DIY the design. Maybe installation, but not the design of the steel.
Based on the information contained in this post, a Structural Engineer should really be hired to run all the calculations. There are intricacies of replacing structural steel in a building that you may not even be aware.
jcarlilesiu is offline   Reply With Quote
The Following 2 Users Say Thank You to jcarlilesiu For This Useful Post:
AndyGump (06-12-2012), mae-ling (06-12-2012)
help a girl out? window replacement with steel siding indynile Windows and Doors 16 02-22-2016 07:01 AM
replacement half moon window steel door SAM.P. Windows and Doors 1 09-22-2011 06:09 AM
How to replace 10"x6" Wood Girder and with the steel? What size it would be? Tzilya Building & Construction 1 07-28-2010 05:19 PM
Girder Steel or Wood Jameson1 Building & Construction 11 03-12-2010 06:38 PM
Shower faucet replacement - PVC replacing steel? jdm1 Plumbing 2 11-29-2008 12:38 PM
