Steel Rebar In Poured Concrete Basement Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-20-2011, 02:23 PM   #1
Steel Rebar in Poured Concrete Basement Walls
What is the best way to remove these rebars that stick out everywhere on my poured concrete basement walls. I am in the process of putting XPS down on the walls but need to get rid of these bars first. I was able to pull one out but the others are pretty stuck in there. Should I patch up the holes when finished removing them? Water has never leaked out of them. Or should I just put the XPS through them? It will kinda help out with keeping them to the wall better. Newbie here - dont know the best route?
https://picasaweb.google.com/lh/phot...eat=directlink
rickcet is offline   Reply With Quote
Old 10-20-2011, 02:43 PM   #2
Rewards Points: 2,238
Those look like "wall-ties" -
"Re-bar" is buried in the walls -
Wait and see if one of the concrete Pros respond to this -
rossfingal
rossfingal is offline   Reply With Quote
Old 10-20-2011, 02:51 PM   #3
joed's Avatar
Rewards Points: 11,516
Yes, those are the form ties. Contractor should have remove them. Bend them with a hammer. They should snap off. Put a blob of sealent over them to prevent any leaks.
The Following User Says Thank You to joed For This Useful Post:
rossfingal (10-20-2011)
Old 10-20-2011, 03:00 PM   #4
Thanks "joed"!
RF
Old 10-20-2011, 08:58 PM   #5
Concrete & Masonry
Rewards Points: 468
Not a wall tie, just what looks to be a 2 1/2" to 3" masonry nail from "who knows what". I would just hit it sideways & up & down a few times until it falls out. No other work needed.
jomama45 is online now   Reply With Quote
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 04:49 PM
Insulating poured concrete basement walls Dude Building & Construction 0 03-03-2010 01:24 PM
painting basement concrete walls ctkeebler Building & Construction 6 11-17-2009 04:23 PM
Removing concrete poured over tile in basement nkjetman Building & Construction 6 01-31-2009 05:55 PM
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 01:21 PM
