Old 11-16-2010, 10:14 PM   #1
Steel post in concrete
Hi I am building a pergola in south Florida. I have an existing patio slab. I have two questions, I am planning on using 3x3 galvanized steel posts 3/16 thickness.
I would like to know what the gurus think.
1. Should I bolt the columns to the slab using 4 anchors per post. Or should I cut footings in the concrete slab, and dig a 40 inch footing, and place the post in the concrete.
I am leaning towards cutting the concrete and placing the footer into the concrete. Should I worry about the posts rusting at the base. Should I seal the top of the tube, to prevent water from gathering in the tube. What should I know about before embarking down this road. Thanks in advance.
Alex
alexj212 is offline   Reply With Quote
Old 11-17-2010, 07:04 AM   #2
With the prospect of hurricanes and that pergola becoming airborne, I would set the posts in concrete. And use tie brackets on everything, which is also tied to the posts.
Old 11-17-2010, 09:23 AM   #3
Thanks - thats what I figured, Now with the galvanized steel posts, the tube is hollow, Do I need to cap the end sticking out of the ground, so that moisture does not enter the tube. When sticking the posts in the concrete, once I have the concrete in the footing, Will I just be pushing the tube into the concrete or have the post in the concrete and pour around it. If I pour around the post wont the center of the post be empty? Thanks
Alex
Old 11-24-2010, 10:17 AM   #4
Maybe you should think about using aluminum posts. I live in South Florida s well, and I have steel columns supporting my patio. They are rusted and are in need of replacement.
mauricior is offline   Reply With Quote
Old 11-24-2010, 02:19 PM   #5
biggidybankston's Avatar
Years ago, I worked in a machine shop who's primary customer was a company who made metal awnings and whatnot. Primarily everything was aluminum, but I remember distinctly that they took a 2 way approach to metal posts: They were capped at the top to stop the water getting in, and drilled at the bottom to let the water out. No matter what you do, sooner or later water will probably find a way into the post, and its best if it has a way out.
biggidybankston is offline   Reply With Quote
mounting 4x4 wood post to concrete porch pshinaults Building & Construction 1 05-27-2010 03:53 PM
Picking a foundation for shed/simple workshop Corey in NE Building & Construction 30 02-08-2010 12:34 PM
Getting Steel Plate Flush with Concrete Floor MrBill_DIY Flooring 7 11-29-2009 09:54 AM
Concrete or Steel Pier Foundations? TheBeetleGuy Building & Construction 7 09-21-2009 03:57 PM
Concrete curing in post holes moneymgmt Building & Construction 5 11-19-2008 11:01 AM
