Steel I BEAM Size - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-08-2012, 10:41 PM   #1
Steel I BEAM size
I need advice /help
I have a 2 story house with a full attic that you can stand up in the middle parts of.
In my basement I have 2 poles that are supporting a wooden beam going across a length of approx 22 feet. I want to remove one of the poles to open up my basement. I had a iron work company come in and said it was no problem to remove 1 if not both poles. He said that he would use 24lb (something like that) weight if I wanted to remove both poles. One end would be supported by the foundation of the house and the other by a third pole which is next to a chimney.
Another company said I could do one but they never mentioned about getting rid of both.
Does this sounds correct? What type of questions should i ask the guy about the size and strength of the I Beam. He seems very confident that I could get rid of both but I dont want to say yes if it doesnt seem correct.
whatsupteach is offline   Reply With Quote
Old 04-08-2012, 10:43 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
You need the advice from a local engineer, not from another part of the world.
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
woodworkbykirk (04-09-2012)
Old 04-08-2012, 10:51 PM   #3
cortell's Avatar
Rewards Points: 504
Absolutely. No vendor of any material should ever tell you what is an acceptable structural change--especially something as critical as changes to beam supports--unless that person is a licensed engineer. In fact, to be honest, I'd avoid using any of the guys that gave you advice. They should have told you what we 're telling you: hire an engineer.
cortell is offline   Reply With Quote
Old 04-08-2012, 10:57 PM   #4
Framing Contractor
Originally Posted by whatsupteach
I need advice /help
You need an architect or engineer to tell you what size beam you need to remove either one or both colums. You also need permits and inspections. Planning on getting them?
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
PaliBob (04-08-2012)
Old 04-08-2012, 11:22 PM   #5
General Contractor
If the iron work company didn't mention permits or engineering, then don't call them back, they are incompetent. Find another contractor to come and look at it.
KennMacMoragh is offline   Reply With Quote
The Following User Says Thank You to KennMacMoragh For This Useful Post:
AndyGump (04-08-2012)
Old 04-09-2012, 07:57 PM   #6
Rewards Points: 282
forget the beam, thats the easy part, the footing under that 3rd pole (and the 3rd pole itself) will have a 50% increase in load (going from 33/33/33 to 50/50)...
i would be concerned about that.....thats the hard, backbreaking work.
jcrack_corn is offline   Reply With Quote
Old 04-09-2012, 08:02 PM   #7
Framing Contractor
Rewards Points: 118
The place where we get our steel can do the engineering there. Often while you wait on something fairly simple. Not sure that is the type of service he is getting though. I agree with the footing issue. I can almost guarantee whatever footings are there now will not carry additional load.
sixeightten is offline   Reply With Quote
Old 04-09-2012, 08:07 PM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
My advice is the same as previous posters: You NEED to get that information from an engineer, an engineering firm, or a supplier that will also provide the engineering calculations and certification (this will be required by all city/town/regional Building Departments, issuing project building permits).
- Build Well -
Old 04-10-2012, 12:16 AM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,500
Yea......you need input from a 'qualified' engineer and/or architect.....
To give you an idea of the extent of the task....click on the 2-story addition link in my signature....I'm using a steel beam....6"x10"...around 14' long....3/8" steel....and it's only supporting part of my second story floor....not 2 floors.....
Yea....you need engineering....
Old 04-16-2012, 12:40 PM   #10
Rewards Points: 398
My house was built with a 6"-wide steel I-Beam in my basement for the main support and I still have one vertical support pole.
The beam is a little over 30' long and supports 2 floors and a full size attic.
x2 on the engineer.
adgjqetuo is offline   Reply With Quote
Old 04-16-2012, 01:05 PM   #11
Rewards Points: 2,516
Originally Posted by whatsupteach View Post
I need advice /help
The type of question you should ask is, "Do you have current liability insurance?"
hammerlane is offline   Reply With Quote
Old 04-16-2012, 01:19 PM   #12
Civil Engineer
Rewards Points: 4,704
You can always get rid of posts, it is a matter of how to design the support system to function correctly without the posts. Usually this type of design is done by a licensed structural engineer, as has been noted by everyone else on this thread. If the contractor is also a licensed engineer, no problem, they can handle the entire process. As discussed, make sure they carry professional liability insurance, general liability insurance, and plan to pull the appropriate permits.
In terms of discussing their plan, you should verify that they have done this sort of work before (call their references), and make sure they will furnish a set of drawings and computations to you for your review BEFORE they begin the work.
Daniel Holzman is online now   Reply With Quote
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Pros and cons to wood vs steel I beam framing buildings viper Building & Construction 1 05-22-2011 05:17 PM
What size beam to support loft with 16' between supports paperman Building & Construction 3 10-06-2009 05:40 PM
attaching garage loft support to 12 inch steel I beam lospinoj Building & Construction 4 09-14-2009 01:38 PM
Steel Beam or Wood Reinforcement for 2nd floor addition? coralhead1 Building & Construction 2 06-06-2006 01:22 PM
