Steel I Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 01:43 AM   #1
steel I beam
can a 8"x 4" 1/4" span 22'?
stich is offline   Reply With Quote
Old 02-18-2012, 07:31 AM   #2
Experienced
Jackofall1's Avatar
Sure you just can't put anything on it.
The deflection by the sounds of what you described as an W8 x 15 spanning 22' under it own weight would not be acceptable, let alone putting any load on it.
Beam sizing is typically left to the pro's, find one pay them to design a support system at least that way you will not have to worry about your structure collapsing.
Old 02-18-2012, 01:03 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 812
Ditto on what Jack said.....and that beam will not span that distance safely.....
I built a garage about 3 years ago.....I was cosindering using a steel beam to span 20'....it would have needed to be a 6x10 3/8" thick.
Believe it or not....PSL might be a better choice...but you need to get engineering calcs on it.....
Nice thing about PSL's....a lot eaiser to cut and drive nails into than steel beam....
ddawg16 is online now   Reply With Quote
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 09:39 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
Steel beam for deck billybarty Building & Construction 2 08-18-2010 01:27 PM
steel beam length otto man Building & Construction 4 07-27-2008 09:11 AM
