Hi Everybody.
Have another fun problem with my theoretical 2nd floor additiion. My current house, a single story brick (approx 1600sqft) built in 1979, was built on 24" centers. This was apparently legal in Texas for about 2 years, if 3/4" ply skin was applied, then brick. My building line will not allow me to build out without exeptions from the army corps of engineers (which isnt going to happen). reason for addition would be quality of life...I wont be able to afford/find a better house on better property in this area. Others are starting to add on for the same reason.
I cannot level up without reinforcing/supporting the walls. I am trying to weight the cost/feasibility of 1) tearing out sheetrock and adding 2x4/4x4 supports, then re-sheetrock or 2) thinking outside the box and sinking steel beams which would support a steel cap plate/beam (basically building the second floor on stilts above the first floor). I could brick in the beams to look like pillars/decorative.
tearing out the sheetrock and re-supporting would entail a huge mess and at least half the house being unlivable for a time. I have to admit the beam idea is mine and I dont even know if its feasable structurally, let alone monitarily, but Ive floated it by a couple of GCs and they seem to think it can be done (after an initial look like "are you nuts?").
any ideas here? I have never built with steel, so I dont know costs or limitations, but in a perfect world the beams could be set exterior and attatched to the house (or possibly interior over the footing), with the cap beam being laid just under the eves, ready for the 2nd story walls to be attatched after the eves are removed, with minimal interior damage to the house.
