-   -   steel beam length (http://www.diychatroom.com/f19/steel-beam-length-24239/)
otto man 07-25-2008 02:02 AM
steel beam length
I am trying to figure out what the smallest steel beam possible is to span 28' while supporting a deck with a dead load of 300 lbs and live load of 1200 lbs. The deck will be supported at one end by this beam and at the other end by a wall to my house which is quite sturdy. The decking will be redwood 2x6s that extend from the house to the beam. Is a W8x10 too small? It's a long span, but the steel beam won't be expected to support much weight. Is there such a thing as a W10x10? I'm just looking for a ball park estimate. Nobody at the place where I buy my steel speaks english very well so I can't get even a rough guess.
Termite 07-25-2008 07:39 AM
I'd strongly suggest contacting a structural engineer for this task.
concretemasonry 07-25-2008 08:02 AM
Your load looks low, but you did not provide enough details like deck size and location. Is that total loads or per foot loads?
Strength is one thing. At 30' long, you will probably have more problems with deflection and a springy deck.
Not for an amateur to design.
Dick
billie_t 07-26-2008 11:28 PM
you do need an engineer but a ball park figure for what you are thinking of is half your span in feet.... in inches of beam....this is no formula for substituting an engineers stamp but i think it will be close to a 14 inch beam of medium weight
28 feet devided by 2 = 14 feet = 14 inch beam
AtlanticWBConst. 07-27-2008 08:11 AM
Try another supplier. Most have a service to provide you with the calculated beam dimensions, and engineer-stamped specs, which may be required in order to get, and approve, a permit and inspection.
