Old 08-18-2010, 12:35 PM   #1
Steel beam for deck
I want to build a 40 x 16 dec off the front of my house and have as much room underneath to enter the garage. I would like to get away with using only 2 posts if I can and this is what I am hoping will work. The deck is 10 feet high and I am planning on using a 6 inch piece of steel well casing as the posts with a 40 foot steel I beam resting on top for the joists. The deck is 16 feet deep and am going to put the beam at the 12 foot mark and cantilever 4 feet using 2 x 10 joists 16 inch on center. Is this possible and if so, how thick an I beam should I use? Being that it is steel and thick joists should I still worry about bracing between the posts and the beam?
billybarty is offline   Reply With Quote
Old 08-18-2010, 12:56 PM   #2
Steel beam for deck
You would need to find out if you can build such a structure off the front of the house from the local oversight body. Then you would need to have plans engineered for the structure and have them approved.
Ron
Old 08-18-2010, 01:27 PM   #3
Steel beam for deck
This is a cottage I have that is on a resort on a local First Nations reserve so there are no building codes or regulations of any kind. I thought someone on here might be able to point me to a place that shows unsupported spans for different thicknesses of beams.
Question about steel I BEAM in basement djohns10 Building & Construction 7 06-23-2012 04:55 PM
attaching garage loft support to 12 inch steel I beam lospinoj Building & Construction 4 09-14-2009 02:38 PM
steel beam length otto man Building & Construction 4 07-27-2008 09:11 AM
Steel Beam in Basement Heinz Building & Construction 2 11-10-2007 01:11 PM
Steel Beam or Wood Reinforcement for 2nd floor addition? coralhead1 Building & Construction 2 06-06-2006 02:22 PM
