-   -   Steel beam for deck (http://www.diychatroom.com/f19/steel-beam-deck-79074/)
billybarty 08-18-2010 11:35 AM
Steel beam for deck
I want to build a 40 x 16 dec off the front of my house and have as much room underneath to enter the garage. I would like to get away with using only 2 posts if I can and this is what I am hoping will work. The deck is 10 feet high and I am planning on using a 6 inch piece of steel well casing as the posts with a 40 foot steel I beam resting on top for the joists. The deck is 16 feet deep and am going to put the beam at the 12 foot mark and cantilever 4 feet using 2 x 10 joists 16 inch on center. Is this possible and if so, how thick an I beam should I use? Being that it is steel and thick joists should I still worry about bracing between the posts and the beam?
Ron6519 08-18-2010 11:56 AM
You would need to find out if you can build such a structure off the front of the house from the local oversight body. Then you would need to have plans engineered for the structure and have them approved.
Ron
billybarty 08-18-2010 12:27 PM
This is a cottage I have that is on a resort on a local First Nations reserve so there are no building codes or regulations of any kind. I thought someone on here might be able to point me to a place that shows unsupported spans for different thicknesses of beams.
