Starter Strip For Vinyl - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 12:52 AM   #1
starter strip for vinyl
starter strip for vinyl siding - should just click in, correct?
When it appears to be in, I go to put the nail in, and it pops out - every time!
Don't know if it's my technique, the metal starter strip, or what...
maxwell_smart00 is offline   Reply With Quote
Old 12-17-2011, 07:16 AM   #2
Rewards Points: 2,240
If the starter strip is aluminum or steel - the siding will not "click"/snap in.
It will "snap" in if the starter strip is vinyl.
If you're going to use metal starter strip - you have to hold the first panel into the starter -
knee, foot, something - while you nail it.
Better - have someone hold the panel up.
rossfingal
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
DangerMouse (12-17-2011)
Old 12-17-2011, 11:56 AM   #3
firehawkmph's Avatar
Rewards Points: 1,920
Ditto on what Ross said. One additional thing I do is measure the total height of the panel and measure up from the bottom of the starter strip and snap a chalkline. Just a way to make sure you pull the first row up all the way and get off to a straight start. I also pull the panel up snug, still nailing in the middle of the slot. The bottom panel will not necessarily slide side to side as easy as the ones above it. Not a problem. I do prefer steel starter strip over the aluminum or vinyl starters. It is much more ridgid and helps get off to a good start.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
rossfingal (12-17-2011)
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 02:58 PM
No starter strip used on shed roof install? waterskier_erie Roofing/Siding 4 10-31-2011 08:25 PM
siding starter strip cbzdel General DIY Discussions 2 08-03-2011 03:49 PM
why does starter strip have glue on it if it goes on tar paper? KarlJay Roofing/Siding 4 11-24-2010 02:05 PM
No starter strip!?! hockeyhead Roofing/Siding 10 09-17-2005 11:54 AM
