Old 01-04-2011, 11:48 PM   #1
Question
Started Exposed Brick Wall, Studs within brick, should I stop?
I recently purchased an old, brick duplex, built in the 1920's in St. Louis. The upstairs bedroom has a nice exposed brick wall, on the side of the building.
I'd like to do the same to the lower bedroom, but to the wall that faces the rear of the building. I can tell there has been some water damage to the plaster on that wall, and it looks ugly ... which is another reason I'd like to remove it and expose the brick (besides that I like the look). I purchased it after a rehab. It has been tuckpointed and I believe the water issue has been corrected.
I started creating some test holes and found brick directly behind the plaster as expected. I started getting more confident and made a bigger hole. After creating a hole about 4 inches wide, I saw a stud within the brick. Once I broke the surface of the plaster, the plaster behind it came out almost like sand. The stud felt a little soft and moist to the touch.
I was not expecting to find a stud placed within the bricks. Should I expect to find more studs within the brick? The one I found appears to be in a vertical line with the window edge.
I'm concerned that studs within the brick will look unattractive if I expose the wall, and I'll be sorry if I continue the project. I also noticed that the brick on the right side of the stud does not appear to be completely flush with the brick on the left of the stud. I'm also concerned that the stud feels soft and moist.
Should I continue removing plaster to expose the brick or is it too much of a risk? What's the worst that could happen?
I'd appreciate your thoughts very much!
Started Exposed Brick Wall, Studs within brick, should I stop?-img_0144.jpg   Started Exposed Brick Wall, Studs within brick, should I stop?-img_0233.jpg   Started Exposed Brick Wall, Studs within brick, should I stop?-img_0236.jpg
perry167 is offline   Reply With Quote
Old 01-05-2011, 12:40 AM   #2
The worst that could happen is to repair what you removed.
epson is offline   Reply With Quote
Old 01-05-2011, 10:36 AM   #3
How is no insulation needed on outside walls in a bedroom in St. Louis?
bob22 is offline   Reply With Quote
Old 01-05-2011, 10:39 AM   #4
Stay-at-home GC
Welcome to the 1920's when oil and coal were going to last forever!
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 01-05-2011, 10:41 AM   #5
"Welcome to the 1920's when oil and coal were going to last forever!"
That part I get; what I don't understand is why you would want that in 2011?
Tags
brick wall, remodeling
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Garage brick wall repair TANME General Discussion 2 02-04-2010 07:19 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Repairing rotted studs against exterior wall sleepyscout Carpentry 11 07-01-2009 02:31 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
