Stapling Into Engineered Joists? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-19-2013, 07:53 PM   #1
Rewards Points: 980
Stapling into engineered joists?
I am hanging some ducts for my dust collection system and it would be nice to staple the plastic strap hangers into the joists.
I read their instructions, and while you can put some pretty big screws into the bottom, they recommend against putting anything into the sides.
I assume they mean screws; 18 gauge staples seem pretty harmless.
(I see neither the plumber or HVAC guy who built the house had any qualms about nailing into the sides, but they didn't pay close attention to code either...)
What do you think?
Toller is offline   Reply With Quote
Old 03-19-2013, 08:01 PM   #2
Rewards Points: 13,732
You can use roofing nails, staples, screws, not going to have any effect on them.
Old 03-20-2013, 01:38 AM   #3
Rewards Points: 212
Depends on what you mean by "sides" . If you mean stapling into the side of the flange (the top or bottom of the joist) my understanding is that you're not supposed to do that as it splits apart the layers of the laminaated veneer lumber, sort of like nailing into the edge of plywood. If you're talking about stapling into the OSB web, the middle part between the flanges, it shouldn't compromise the joist, but the staple might not hold a lot of weight.
A Squared is offline   Reply With Quote
Old 03-20-2013, 10:20 AM   #4
Rewards Points: 980
I meant the flanges. Like I said, the instructions say not to do it (presumably for the reason you say) but a staple isn't much. I attached some cables to the web using wire staples and they don't hold very well; so I don't think they would hold my pipes at all.
The plumber nailed many of the pipe holders in from the side, but he didn't do other things right.
Actually I just put a screw hook in from the bottom and found it was easy enough to hang the duct from that; so I am good.
engineered i joists Rod M Building & Construction 2 09-24-2012 09:08 PM
Polystyrene between attic joists or on top of joists? seanog Insulation 7 08-27-2012 05:55 AM
Adding additonal joists use engineered wood? Velvis Flooring 1 03-25-2012 03:49 PM
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 05:28 PM
Basement cable location on joists BasementVirgin Electrical 12 02-24-2010 10:56 AM
