Stapler That Will Work On My Wooden Fence - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 04:21 PM   #1
Stapler that will work on my wooden fence
Hello,
We have a 4 rail wooden fence(725 LF) and i need to attach wire mesh to keep the dogs from getting out and the rabbits from getting in . I have tried using a variety of "heavy duty" staplers but the staple either bends or doesnt go all the way in. Ive tried using a hammer to pound the high ones in but it never seems to work.
Here is what we have now...
This is what we're shooting for.
It probably would have been easier if the fence builder did this at the time of installation, but we are where we are and I need something that will allow me to do some rapid-fire stapling.
Any suggestions for a pneumatic or electric solution?
nkrid is offline   Reply With Quote
Old 08-26-2012, 05:11 PM   #2
kwikfishron's Avatar
Rewards Points: 92
Welcome to the Forum.
THIS (or another brand counterpart) is the gun you want to use.
You should be able to rent it. I'd use stainless steel staples.
kwikfishron is online now   Reply With Quote
Old 08-26-2012, 05:13 PM   #3
Rewards Points: 12,878
Since it's pressure treated your going to have to use as a minimum electro galvinized staples, stainless would last longer.
Only ones I could find that work in a gun are these.
http://www.bandceagle.com/fasteners....uction_staples
Another way would be to just tack up the fencing and go back over the back side with another layer layer of 1 X 6 Pressure treated board using ring shank stainless steel fencing nails.
That way I know the dogs can not knock it off.
I hope you have small dogs, a bigger one can go right over the top.
Old 08-26-2012, 05:18 PM   #4
Rewards Points: 3,370
Have you checked to see if you can pick up a cheap air stapler from Harbor freight or Amazon,if not maybe rent one from HD,thats the only easy way you'll get staples in that fence.
Canarywood1 is online now   Reply With Quote
Old 08-26-2012, 07:35 PM   #5
Did the exact think you are doing with a cheap harbor freight narrow crown stapler pneumatic with galvanized staples. As i've tried making repairs I still break out the pneumatic as the electric or hand staplers won't drive in enough to hold.
jeffh110 is offline   Reply With Quote
Tags
fence , stapler
How many hours to do this work? brainfogbetty Drywall & Plaster 17 10-26-2011 05:17 AM
Converting a fence taqwus Landscaping & Lawn Care 6 05-19-2011 01:18 PM
Corrugated steel fence? ITSANSS Landscaping & Lawn Care 2 04-13-2011 08:04 AM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 09:05 PM
Frustrated/Confused in FL Fence jjrbus Building & Construction 5 09-02-2009 10:52 AM
