Standard Patio Door Into 2x6 Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-28-2010, 02:48 PM   #1
standard patio door into 2x6 walls
can i purchase a stadard patio say from Home Depot and install it 2x6 walls. Can this be done or do need to order a door for 2x6 walls which is a special order.Also cost about $300 more and 3-6 week wait.
bobsue109 is offline   Reply With Quote
Old 08-28-2010, 03:11 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
Yes you can, it has been done many times before. Be sure the filler or jamb extenders are on the inside of the door as it will cause water problems on the outside of the doors. When I installed the extra width to extend the jamb, I would let there be a 1/8-1/4 inch reveal to make it look as though it were planned that way. I always made an aluminum pan to go under the door's threshold to keep the water out.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
bobsue109 (08-28-2010)
Old 08-28-2010, 03:26 PM   #3
My front door is a door for 2x4 wall in a 2x6 wall
Be aware that it will not swing totally open
IE 180 degrees back againt the inside wall
My door does open past 135 degrees
Since I have a bench on the 3 season porch it can't open any wider then that
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Old 08-28-2010, 04:25 PM   #4
Old School
Willie T's Avatar
A few ways to get your door to open wider.
Willie T
Old 08-28-2010, 09:37 PM   #5
Registered User
Rewards Points: 4,936
Is this an entry swing door, a french double door, or a sliding glass patio door?
Gary
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
need help evaluating patio work (photo) patio_newbie Landscaping & Lawn Care 6 07-11-2010 10:53 PM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 08:45 AM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 03:43 PM
Should I open up my enclosed patio? diyimk Building & Construction 4 07-14-2008 01:38 AM
