Standard Ceiling Height - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-30-2008, 12:22 AM   #1
standard ceiling height
is there any way to find out the standard ceiling height by house type (flats, houses...)? is there a regulation on ceiling height?
iggy525 is offline   Reply With Quote
Old 12-30-2008, 12:31 AM   #2
Registered User
Termite's Avatar
By using the term "flats" I'm assuming you're not in the states???
Here in the states, wall heights are typically 8', 9', and 10', with 8' being the most common in most areas. Code requires 7' at a minimum, with 6'-6" allowed at non-repetitive beams that drop below the 7'.
Old 12-30-2008, 12:34 AM   #3
General Contractor
Standard ceiling height in my area is 8'
7'6" is the minimum for habitable space allowed by code in my area. This may vary depending what code system is in use where you are.
jensenconstruction is offline   Reply With Quote
Old 12-30-2008, 12:36 AM   #4
I assume 8' works well with construction methods as drywall and plywood comes in 8' lengths?
sunthas is offline   Reply With Quote
Old 12-30-2008, 12:36 AM   #5
Registered User
Termite's Avatar
For reference, I'm citing the International Residential Code.
Old 12-30-2008, 12:40 AM   #6
General Contractor
you should be thinking about the width, as these materials should be install horizontally, not vertically.
Drywall is also available in 54" widths so 2 sheets will do a 9' ceiling.
Old 12-30-2008, 12:42 AM   #7
General Contractor
We just switched over to the IRC here, however I worked with the UBC for so long thats what came to mind. I'm still transitioning over.
Old 12-30-2008, 02:48 AM   #8
i'm actually trying to figure out kitchen dimensions in London area. (but i'm not actually in London)
ah, this is difficult...
Old 12-30-2008, 12:53 PM   #9
54" x 8' sheets or 54' x ?
Old 12-30-2008, 09:05 PM   #10
General Contractor
Yes 54" x 8" so 2 sheets install horizontally will give you your 9'. Also great as it eliminates the extra joint you would have using standard 48" board.
You can find it at a drywall supply yard, The box stores don't carry it.
Old 12-31-2008, 12:31 AM   #11
sweet, thanks, I was thinking would want to go 8' walls all the time to cut down on wasted resources and labor, but 54" drywall solves that issue!!
Height of a ceiling fan with a trey ceiling? Bacardi 151 Electrical 7 09-08-2010 11:55 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Code for basement ceiling height RDS Building & Construction 3 04-22-2008 11:46 AM
Take down drywall on bedroom ceiling to add height clkad Carpentry 10 03-23-2008 01:04 PM
raising ceiling height during remodel marks Building & Construction 1 10-04-2006 02:58 PM
