Stairwell Opening In Wood Joist Floors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-12-2010, 09:48 PM   #1
Question
stairwell opening in wood joist floors
What do you do when the width of the opening of your new stairwell doesn't butt up against an existing joist! No opening has been cut yet...still in the planning stage of the game. We are converting our attic into a living space and need to install a stairwell. Our house is pretty old and the wood joists are 2"x10", 28" on center apart. The opening required is 5'-0" wide but this ends up between 2 joists. I'd have to put 5 trimmer joists to get to the next existing joist...there has got to be a better way to support the length of the opening!
Galatea is offline   Reply With Quote
Old 10-12-2010, 10:16 PM   #2
Rewards Points: 1,092
It sounds like you are walking up into the attic, parallel to the floor joists and will have to cut one floor joist off short and install a header. ???? I'm not sure I'm using the term "header" here correctly, but that is what I'd call it. You cut the joist, run a board or 2 perpendicular to it, and nail that to the joists on either side; the adjacent joists will now carry its load. (BTW: That may overload them, so have someone check out your plan. Any posts or supports for those adjacent floor joists going in to help them out?) Can't you just install a couple of blocking piece and run a board between it and your header, parallel to the floor joists? Maybe I'm not seeing what you are doing, but it sounds pretty simple; you are just hanging in a new, very short floor joist at the edge of the stairway opening. No? j
The Following User Says Thank You to jklingel For This Useful Post:
BigJim (10-12-2010)
Old 10-12-2010, 10:46 PM   #3
jlhaslip's Avatar
Rewards Points: 1,402
The long joists are typically doubled with the "header" mounted using joist hangers.
The "header" is another double.
Also use a joist hanger to mount the cut joist to the backside of the "header".
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 10-13-2010, 12:04 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 280
Jl is right on with the drawing. A question for you, how long is the span that your joist make? 28 inches on center might be too much for your joist if the span is too wide. If it were mine I would put another joist between the existing joist.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 10-13-2010, 09:28 AM   #5
drawing to go with my question
future attic stairwell.doc
Here's a drawing of the existing joist and the location we're planning for our stairwell. Hope this help to better explain what we are dealing with.
Old 10-13-2010, 11:26 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 280
There must be a wall somewhere supporting the joist. The only joist I have seen that long are engineered and you said it is an older home so chances are they aren't engineered joist. I am not trying to be picky but we need to know exactly what you have before we can offer advise.
One more question, what is the pitch of your roof? If you have the stairs too close to the wall the rafters rest on you may not have enough head room.
Jim
Old 10-13-2010, 01:03 PM   #7
Additional Details
the walls beaneath (living room on main floor) are drawn in pink and . The roof pitch is 9:12. We are installing a pre-fabricated 48" spiral staircase. The celing height where the new stairs would exit onto the attic floor is 8'-0"
Old 10-13-2010, 01:05 PM   #8
drawing of joist plan
peak of roof is marked with a pink dashed line (left to right on drawing)
Old 10-13-2010, 01:37 PM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 280
As for head room you will be fine as you will have a minimum of 81 inches on the low side of your stairs. I would still be concerned with the spacing of your joists though. Another couple of things is you will be limited with the size of objects you will be able to get upstairs as the spiral stairs will be narrow. In this area we have to have another set of stairs as that is code. I really don't know how that is up your way but for sure a fire escape is a necessity. I would recommend talking to your code enforcement to be on the right side with them about the joist, extra stairs and fire escape.
Jim
Tags
floor , joists , opening , stairwell
Old Wood Floors scook5439 Flooring 1 09-04-2010 11:13 AM
Easy way to reseal (?) wood floors? boinsie Flooring 3 04-26-2010 07:52 AM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 07:19 PM
Pet damaged wood floors.. paint them?! awoods Painting 3 03-05-2009 05:56 PM
Furniture on wood floors antonyg Interior Decorating 2 11-28-2008 10:28 AM
