Old 07-20-2011, 10:32 PM   #1
Stairway wall help.. (Code question)
We currently have a closed in staircase leading to our basement.. we are going to do this to it:
Does anyone here know what finished height the "half wall" (is that correct?) would have to be. I looked at some code guidelines, and could only come up with a railing or baulister height.. Would the height of my railing on the opposite side of the stairs be good enough? Thought? Insight?
casper129 is offline   Reply With Quote
Old 07-21-2011, 09:16 AM   #2
Architectural Designer
AGWhitehouse's Avatar
Check that code again and look for "Guardrail" height requirements. The handrail is a seperate animal. Residential codes usually only require 1 handrail and it can be placed on either side of the stair.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-21-2011, 11:00 AM   #3
check photo #36 - guard height
http://www.stairways.org/Resources/D...20download.pdf
jrepp44 is offline   Reply With Quote
Old 07-21-2011, 01:08 PM   #4
jrepp44 - Thanks, that's kind of what I was going off of at first, but I didn't know if the half wall would be called a guard rail.. From what I understand from your image, the wall must be at least 36" high, but it can be higher if I wanted.. ( I think I have it drawn out with a finished height of 38" right now...)
Old 07-21-2011, 01:11 PM   #5
CT Guardrail Heights = 36" for residential, 42" for commercial
Old 07-21-2011, 03:39 PM   #6
concretemasonry's Avatar
casper -
Contact your local code people. Any model code (IBC. IRC, etc.) can be over ruled by a local requirement as long as the local requirement is more strict or well defined, since a model code is just a MINIMUM and not always what is the right way everywhere.
Wisconsin has always had a reputation for modifying or corrupting other codes, DLIHR is not as strong as it was, but localities still have an authority to impose other standards. - A prime example is the height of the open space on an egress window.
Dick
concretemasonry is offline   Reply With Quote
Old 07-21-2011, 05:24 PM   #7
Alright guys, thanks for the replies.. I will go to my city hall today and see what they have to say...
wall stability question Alvis Carpentry 16 03-18-2011 04:28 PM
Stairway landing code question. Bcoleman6 Building & Construction 4 06-26-2008 10:43 AM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 06:39 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
knee wall question jscholl411 Building & Construction 7 10-10-2007 01:30 PM
