Stairway Help Needed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-16-2004, 12:41 PM   #1
Question
I need to build a steep stairway inside a garage. I am limited to 146" for the total run. The total rise is 132". Can someone help with the rise and tread? All help is very appreciated.
ilikegolf is offline   Reply With Quote
Old 10-28-2004, 05:13 PM   #2
16 stairs @ 8.25" tall X 9" deep.. Hope that helps
ecooke21 is offline   Reply With Quote
Old 11-20-2004, 02:04 AM   #3
Guest
Guest
Posts: n/a
i hope you didn't build your stairs yet.
There is always one less run than rise. The correct answer is 16 rises at 8.25" and 15 treads at 9.73". However, you may want to check with your building codes, I think minimum on a tread is 10" and max on a rize is 8".
Good luck ~ Gooshimo online ~
Old 11-20-2004, 06:38 AM   #4
I do believe you're right. As far as I know it's been 8" on the rise and 10" on the tread. I don't think so, but perhaps your state is different. If that doesn't fit perhaps you can make your opening a little larger. How tall is the ceiling. Maybe we can suggest another idea.
Hammertime is offline   Reply With Quote
Old 02-13-2005, 10:05 AM   #5
Two steps to a platform with a 90 degree turn put me into compliance one time when space was a restriction.
Tomm is offline   Reply With Quote
Old 03-13-2005, 02:32 PM   #6
RSRS=17 R-SZ=7.75"overage underage .25" 16 treads,T-SZ=9.25" overage underage 2" stringer length 191.75" degree of inclination=40.4
RSRS=16 R-SZ=8.25" overage underage=0" TRDS=15 T-SZ=9.75" overage underage=.25" stringer=191.5" degree of inclination=40.3
BKFRAMING is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
Help on materials needed for granite tile c4m4r0 Flooring 4 06-02-2007 02:05 PM
Stairway loose asegal General DIY Discussions 4 12-02-2006 04:00 PM
Size of laminate layout before t-joints are needed wingman Flooring 1 06-22-2006 09:42 PM
