-   -   Stairway Help Needed (http://www.diychatroom.com/f19/stairway-help-needed-220/)
ilikegolf 10-16-2004 01:41 PM
I need to build a steep stairway inside a garage. I am limited to 146" for the total run. The total rise is 132". Can someone help with the rise and tread? All help is very appreciated.
ecooke21 10-28-2004 06:13 PM
16 stairs @ 8.25" tall X 9" deep.. Hope that helps
Unregistered 11-20-2004 03:04 AM
i hope you didn't build your stairs yet.
There is always one less run than rise. The correct answer is 16 rises at 8.25" and 15 treads at 9.73". However, you may want to check with your building codes, I think minimum on a tread is 10" and max on a rize is 8".
Good luck ~ Gooshimo online ~
Hammertime 11-20-2004 07:38 AM
I do believe you're right. As far as I know it's been 8" on the rise and 10" on the tread. I don't think so, but perhaps your state is different. If that doesn't fit perhaps you can make your opening a little larger. How tall is the ceiling. Maybe we can suggest another idea.
Tomm 02-13-2005 11:05 AM
Two steps to a platform with a 90 degree turn put me into compliance one time when space was a restriction.
BKFRAMING 03-13-2005 03:32 PM
RSRS=17 R-SZ=7.75"overage underage .25" 16 treads,T-SZ=9.25" overage underage 2" stringer length 191.75" degree of inclination=40.4
RSRS=16 R-SZ=8.25" overage underage=0" TRDS=15 T-SZ=9.75" overage underage=.25" stringer=191.5" degree of inclination=40.3:)
