Stairs Part 2 Bookshelf Staircase - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-24-2010, 09:50 PM   #1
Rewards Points: 198
stairs part 2 bookshelf staircase
has anyone have exp building this as a basement staircase? it's a 97 year old house and building code can't possibly apply since it's only 6'2 tall. my question is how difficult is this to build and will it be stable? looks like it should be more solid than the standard staircase as the entire weight sits on a larger area on the ground. thanks
vote4Pedro is offline   Reply With Quote
Old 09-24-2010, 10:37 PM   #2
If you rebuild a staircase you could be required to meet todays code
Building codes still apply
Existing work is grandfathered in most cases
Old 09-25-2010, 05:43 PM   #3
Rewards Points: 198
the dims of the room will not meet the requirement with it's low height. i was told that they've looked the other way for many of my neighbors. back to topic tho, anyone has exp building this?
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
Outdoor stairs need to be fixed... 2031pratt Carpentry 4 12-01-2011 05:55 PM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 06:32 PM
Converting an open staircase to a "closed" staircase? tony1853 Building & Construction 7 01-05-2009 01:55 PM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
