Stairs Off Landing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 12:19 PM   #1
Rewards Points: 346
Stairs off Landing
I have pretty much completed repairing (read rebuilding) the landing off the front of our house. The step off the landing was on concrete blocks, the wood just sat on top. Not the way I want to finish the project off!
The stats: landing is 19 inches off the ground. Can I get away with one step, then the ground, or should i have 2 steps then the ground?
If I do step(s), should I use a riser? Does it attach to the front of the landing or the side? If the front, the front of the base or the back of the base? (Clumsily worded, but assume the front is a 2x6, does the riser attach to the front side of it, or does it go in back of it? Prob in back, now that I am thinking of it)
Can I just build a "box on a slab" for one step?
Thanks to any and all ideas!
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 08-23-2012, 01:47 PM   #2
In a little over my head
Rewards Points: 706
There are some pretty specific codes regarding stairs; min/max height, all must be the same, etc. Splitting 19 inches in half with one step won't fly. I think max step height is approx 7 inches.
ratherbefishing is offline   Reply With Quote
Old 08-23-2012, 02:25 PM   #3
Rewards Points: 150
19" is 3 rise 2 steps at 6 5/16" rise
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 08-23-2012, 04:11 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
this link will provide you with the riser and thread requirements of the 2009 International Residential Code. The IRC is the basis of most building codes in the United States. Your code may differ, in Massachusetts we are allowed a maximum riser of 8-1/4" and a minimum thread of 9". A call to your building department of google search for your state may provide a different answer
http://publicecodes.cyberregs.com/ic...9_3_par147.htm
Good luck
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
proper way to build a landing for stairs lslapshot Carpentry 4 07-24-2012 07:23 AM
Small stairs with landing stymie222 Carpentry 11 12-11-2011 10:28 AM
Deck stairs on sand-set brick landing jice Building & Construction 15 08-06-2011 08:34 AM
Deck Stairs with landing ? BDestroyer8418 Carpentry 2 01-29-2011 12:20 PM
The landing at the bottom of the stairs... JS_in_VA Building & Construction 3 11-22-2009 06:19 AM
