Best to be Code-compliant for safety and H.O. Insurance purposes: “R311.3 Floors and landings at exterior doors. There shall be a landing or floor on each side of each exterior door. The width of each landing shall not be less than the door served. Every landing shall have a minimum dimension of 36 inches (914 mm) measured in the direction of travel.” http://publicecodes.citation.com/icod/irc/2009/icod_irc_2009_3_sec011_par002.htm
You got a little work ahead of you to get this right. Where I am at I can have a 4" step to the house from the landing on the outside with an inswing door like you have. So this means when you walk out the door from the house your step can not exceed 4" from the top of the threshold. The landing needs to be 36" deep (off the house) with the width being that of the doorway, being you have double doors that would be both doors. You can get 2 steps out of the 13.5" that you have to the top of the landing, if your 17.5" is to the top of the threshold. Take the siding off and be sure to flash the area properly or you will have big problems.
What is under the house? That is a pretty good size gap that I see.
Personally.....I would remove the siding as mentioned above, drill some holes in the concrete and stuff in some rebar dowels....then pour steps out of concrete. You won't have to worry about rot. Oh, and make sure you put a vapor barrier between the steps and house....what ever you use for steps.
BTW....the width is called 'tread' and the height is called 'riser'. Tread needs to be at least 12" and the riser a max of 7.5. In your case, you are going to have 2 steps, each about 6" high. If you have kids, I would make the tread a little deeper....I would go 14" to make for a comfortable and safe transition outside.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
