Staircase Install - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 01:28 PM   #1
Staircase install
Hi I am trying to put in a new staircase, however the floor joists above run across the new opening. There is only one stud wall on them and this too runs across them, but not in The way of the new opening. My question is how do I keep the strength in the floor because when I cut the opening the joists will no longer be resting on a brick wall at that end.? The new stairs are to run up beside one of the Walls which the joists sit on cheers
Sico40 is offline   Reply With Quote
Old 06-23-2011, 02:00 PM   #2
Rewards Points: 5,336
Post some photos of the area involved so we can see the structure.
Ron
B. Franklin 1759
Old 06-23-2011, 04:20 PM   #3
Will try but getting"error with forum plug in" will persevere.
Old 06-23-2011, 06:36 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
its tough to call without a picture. it sounds like you need to add a supporting wall under the floor before you cut those joists.
Millertyme is offline   Reply With Quote
Old 06-24-2011, 06:49 AM   #5
You need to reduce the size of the picture. Try posting them to a photo place and transferring them here.
Ron
B. Franklin 1759
New deeper kitchen sink install problem jmalcolm Plumbing 3 04-27-2011 10:48 AM
Staircase help please!!! sdba Carpentry 3 02-09-2010 12:58 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Converting an open staircase to a "closed" staircase? tony1853 Building & Construction 7 01-05-2009 01:55 PM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
