Old 01-25-2012, 07:54 AM   #1
Stair terminology
If a set of straight-flight stairs has a really long tread, is it considered a landing or just a really long tread?
jlmran is offline   Reply With Quote
Old 01-25-2012, 08:29 AM   #2
Super Moderator
Stair terminology
Landing typically as 36" or wider---sounds like you are describing wide treads--
Without some numbers what are we talking about?
Old 01-25-2012, 10:00 AM   #3
MarginallyQualified
Stair terminology
For rise/run calculation purposes... it's a tread.
If "really long" (wide?)... then it will quickly stop being a tread.
When it gets out to about 36" (from the riser face) it becomes a landing...
before then it's just a trip hazard.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Willie T (01-25-2012)
Old 01-25-2012, 12:08 PM   #4
Architectural Designer
AGWhitehouse's Avatar
Stair terminology
All tread depths within a flight of stairs needs to be within 3/8" of each other or it is not code compliant. The "odd" tread presents a severe, and dangerous, trip hazard. Landings are a min. 36" in depth as stated unless the stair itself is wider. Then the landing depth must be no less than the stair is wide.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 01-25-2012, 01:47 PM   #5
Stair terminology
This is not a residence. This is where I work. Don't know about code compliance, but I do know these are a pain to navigate if you're not paying attention.
Old 01-25-2012, 02:02 PM   #6
MarginallyQualified
Stair terminology
...these (landings) are a pain to navigate if you're not paying attention.
no doubt.
Old 01-25-2012, 04:37 PM   #7
Stair terminology
Originally Posted by TarheelTerp View Post
no doubt.
Agreed. Yes that is legal and are considered landings...
Repair Stair Stringer sunshine54 Flooring 2 11-28-2011 12:06 AM
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 06:54 PM
Stair Nose Attachment - HELP! BSponz1 Building & Construction 2 01-11-2011 08:51 AM
Stair Nose Attachment - HELP! BSponz1 Flooring 3 01-10-2011 02:31 PM
Stair framing question stubborn1 Carpentry 6 01-19-2009 12:12 AM
