Stair Support Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-05-2011, 05:16 AM   #1
Stair support help
My next project is to secure and support a staircase in a commercial warehouse. The only support it has now is 1 vertical 2x4 attached midway up the side and then the top landing to the second floor. I haven't really worked with stairs so I'm lost on this one...
oddjobrookie is offline   Reply With Quote
Old 12-05-2011, 06:39 AM   #2
DIY staff
Rewards Points: 7,174
Post a picture----are you qualified to work on commercial projects? That is something to think about--
Old 12-06-2011, 04:49 AM   #3
I'll grab a picture some point for you...And I have a licensed contractor if I need him, but he will try to take over the job and the guy I'm doing this for isn't looking to drop a ton of money on the project so I told him I'd see how tough it was...
Old 12-06-2011, 05:01 AM   #4
DIY staff
Stairs if properly built are usually supported only at the top and bottom---
Unless where is something unusual going on the stringers are badly designed or damaged---
A picture will help a lot---Mike---
Old 12-06-2011, 05:05 AM   #5
Ok, I'll be back over there today so I'll take one and post it, thanks
The Following User Says Thank You to oddjobrookie For This Useful Post:
oh'mike (12-06-2011)
Old 12-06-2011, 09:29 PM   #6
DIY staff
We have several members here with lots of stair experience--
Old 12-06-2011, 10:22 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,194
Yep.....I spend lots of time stairing at pictures of pretty girls.....
ddawg16 is online now   Reply With Quote
Old 12-07-2011, 01:54 AM   #8
Old 12-07-2011, 05:59 AM   #9
DIY staff
Those stairs (the stringers and treads) look fine---and properly built--
The landing looks like it's possibly in need of a post or bracket but it's hard to tell without seeing how it's attached to the upper deck.
I believe the vertical 2x4 in the center of the staircase is a stiffener for the hand rail---
What is the customers complaint?
Old 12-07-2011, 06:43 AM   #10
JOATMON
ddawg16's Avatar
For my stairs, I had to use 2x14's on 12" OC....
Old 12-07-2011, 11:04 AM   #11
retired union carpenter
Send a message via Yahoo to coupe
I agree with Mike, Those stairs (the stringers and treads) look fine---and properly built--
the landing looks as though it may feel a bit spongy? I think I'd build a wall under the stinger put in a door and call it storage closet.
just my thought good luck
coupe
coupe is offline   Reply With Quote
Old 12-07-2011, 11:44 AM   #12
Rewards Points: 13,300
Or just a simple 4 X 4 though bolted at the top with two carrage bolts and a Simpson Strong Tie post block at the bottom.
Old 12-07-2011, 01:42 PM   #13
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
I agree, you do need posts for the landing, just not enough support there, I would also add support midway under the stringers.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-07-2011, 10:21 PM   #14
Registered User
Rewards Points: 5,256
If I were you, I’d give it to the licensed contractor. He would be liable- with liability insurance- not you, without any insurance? I could understand if this was your warehouse….
The stair handrail is not to code, the post for the stringer and handrail, the riser/treads are cut from other wood and stuck-on, using single 2x8? for stringers, the top of stringer attachments are not to code- even minimum residential let alone the stricter commercial, the nosing appear past residential code maximum, the landing appears 1-1/2---2” higher rise than the rest, and the landing guardrail picket spacing.
As you have to ask without seeing the few things I spotted at a glance, sub it out to others more capable than you. A permit is required as it is commercial and structural.
Gary
Old 12-09-2011, 12:10 AM   #15
Gary
I appreciate everyone's input...I have a licensed contractor who said he'd help me with any projects this guy throws at me and I think this will be one of them. He has looked at my other work in the warehouse and said it's all good. So I think I'll go that route, thanks guys
oh'mike (12-09-2011)
Stair landing construction rkoutz Carpentry 2 04-19-2011 11:16 AM
Alterative ways to support main beam frizbplaya Building & Construction 8 01-29-2011 12:10 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Basement stair support posts alecmcmahon General DIY Discussions 4 11-26-2010 10:33 AM
stair landings: support by hanging from above? steveel Carpentry 3 09-22-2010 09:12 PM
