Old 08-27-2008, 09:34 PM   #1
Stair Stringer Replacement
I have an old cape cod "montgomery ward kit house" erected in 1946. The stairs are EXTREMELY STEEP and narrow. Run is 7 1/2" and rise is 7". How easy of a job to remove existing treads/stringers and install new with stringer/treads to make stairs safer?
I'd like to do this now before I button up the basement which currently exposes the stairs to the second floor as well as basement.
I have used the attached tool http://www.inspectusa.com/rise_run_s...calculator.php
to assist in planning rise/run and am handy enough to do it. Just never had the need to install stairs in something other than a deck.
Thanks.
usmcstormvet is offline   Reply With Quote
Old 08-27-2008, 10:00 PM   #2
Building codes guy, Mod
thekctermite's Avatar
The toughest part is getting the layout right. Current code requires a 10" minimum run, measured horizontally from the nose (not the riser) of one tread to the plane of the nose below. When going from really old 7-1/2" runs, the location of the bottom landing is going to change 2-1/2" for every tread you have. That is a lot, especially if you have 10 or 12 treads.
Another thing to really consider is headroom. Moving the plane of the stairs outward will greatly reduce headroom if there are any obstructions over the stairs.
My only suggestion is DRAW A PICTURE. A section view of the stairs perpindicular to the risers will allow you to do the math, and verify that you're cutting it right. Never rely only on a calculator to do it...Double check the math against the home's dimensions.
thekctermite is offline   Reply With Quote
More On This Topic
Hi, I'm Steve Chubin at Steve's Sewing and Vacuum Center at King of Prussia, PA and today we are here to discuss how to buy a vacuum cleaner. On accessory vacuums, what you have here is a hand vac. These vacuums are very convenient to use for cleaning... Read More »
Now, with our apron pieces I'm not going to go all the way end to end with these apron pieces. What I want is I want my leg piece to fit just inside the line. So my apron piece is just going to fit just inside, just inside. So normally what I would do a... Read More »
Hi this is Julia Karch for Expert Village.com. In this video series we will be talking about still life drawing for beginners. In this section we are looking at how to get dimension in your drawing and that relies on shading but also volume. So a lot of... Read More »
Hi this is Julia Karch for Expert Village.com. In this video series we will be talking about still life drawing for beginners. An idea to keep in mind is that every form can be reduced to its simplest form which is in kind of a square or rectangular form... Read More »
It is freezing outside right now, but we're warm because we're working out. So this is what we're going to do, we're going to do running up the stairs, scissors on the stairs, and then alternating push-ups, I'm going to show you how it goes. You're going... Read More »
Interlocking pavers & stair leading to house amdspitfire Landscaping & Lawn Care 6 07-21-2008 04:30 PM
Stair Tread Replacement Question Mikedks Flooring 6 07-14-2008 05:04 PM
Stair Stringer capacity for tile? tigerbalm2424 Flooring 5 06-24-2008 11:28 AM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 04:50 PM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 06:54 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
