Old 10-28-2010, 05:09 PM   #1
stair size
According to my contractor my exterior porch stairs will have 3 risers 7 9/16, and 2 treads 12 3/4 each. I am not happy with the dimensions but he said they are perfect. Any thoughts please? Thank-you.
topper is offline   Reply With Quote
Old 10-28-2010, 06:35 PM   #2
STAFF
BigJim's Avatar
stair size
Are you unhappy about the width of the tread or the length of the tread? The height of the riser is pretty well set unless you want to add another step which would make your rise 5.67 inches which is not to code.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
topper (10-28-2010)
Old 10-28-2010, 06:40 PM   #3
stair size
I wanted 3 steps with 4 risers. A 12 inch tread is ok but I thought the riser should be lower. He said nothing can be changed because the skirt is already done.
Old 10-28-2010, 06:46 PM   #4
Ultimatetouch
stair size
Typically rise and run are not to exceed 7 3/4" rise and run is 11". However many people prefer the extra space of the run for sitting or comfort of walking up a deeper run. As long as they are built correctly the numbers are fine.
__________________________________________________ _____________
ultimatetouch is offline   Reply With Quote
The Following User Says Thank You to ultimatetouch For This Useful Post:
topper (10-28-2010)
Old 10-28-2010, 07:08 PM   #5
Moderator
kwikfishron's Avatar
stair size
I was taught that the perfect run to rise ratio should add up to 18” or as close as you can get for a comfortable step. We used this primarily in figuring out landscape steps. So a 5 5/8" rise and a 12 ¾" run is pretty close.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
topper (10-29-2010)
Old 10-28-2010, 07:15 PM   #6
stair size
The rise is 7 and 9/16 so they don't add up correctly.
Old 10-28-2010, 07:23 PM   #7
Ultimatetouch
stair size
#1 for an exterior stair case one should consider grade. Consider intersecting sidewalks, landscapes, foundation, pairs, etc. You dont want your hardscapes to be thrown off because the stairs are sitting to low or to high. Hope that makes sense. If you have a good contractor or builder doing the work this will and should be considered. To many contractors forget about this detail.
__________________________________________________ _______________
topper (10-29-2010)
Old 10-28-2010, 08:40 PM   #8
jlhaslip's Avatar
stair size
7 1/2 " rise and a 10 " run (not including nosing) is ideal.
rise + run = 17.5
rise * run = 75
Those formulas give two targets to aim for.
As the rise increases, the run should decrease accordingly. And vice versa.
Does the 12 3/4 run include the nosing?
According to the code I am familiar with, the nosing needs to be 3/4" min up to 1 1/4" maximum.
Plug the results into those formulas and see how close you get to the 17.5 and 75 answers. The closer the better.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
The Following 2 Users Say Thank You to jlhaslip For This Useful Post:
BigJim (10-28-2010), topper (10-29-2010)
Tags
topper
Size of whole house fan needed Doug Crf General Discussion 20 02-26-2011 12:29 AM
What Size Crown Molding? Jim McClain Interior Decorating 1 10-04-2010 08:16 AM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 06:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
