Stair Construction - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-25-2010, 07:19 PM   #16
Registered User
Rewards Points: 526
I'll bite, what are they?
Be safe, Gary
Old 07-25-2010, 07:46 PM   #17
Old School
Willie T's Avatar
Illegal?
Willie T
Old 08-22-2010, 09:04 AM   #18
stringers
Originally Posted by ovahimba View Post
I'm building my first set of stairs, from an upper deck platform to a lower. It will be 14ft long, 36" wide, using four 2x12s. I plan to leave the outer stringers unnotched and attach the treads using metal brackets. The two inner stringers will be notched.
My reasoning is:
1. This will leave the outer stringers stronger.
2. It will weather better with fewer cut surfaces
3. The placement of railing posts will be easier and allow more flexibility.
However most of the stairs I see in my neighborhood have notched outer stringers. Am I missing something?
you could do that, but it sounds like there is overkill. 3 stringers are fine for up to 4' wide stairs. what i would do on outside stringers is more purest. i hate use of metal when wood joints are available, try cutting a notched stringer then for outside stringers cut channels width of tread material for tread support. lay out same as notched, but above run line add another 1 1/2" line, with skill saw run several cuts at desired depth and remove excess with chisel. presto 26 wood joints !!!!
william4stairs is offline   Reply With Quote
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 05:54 PM
Lighting for stair risers jweiner Electrical 2 04-06-2009 05:18 AM
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 01:47 PM
Stair framing question stubborn1 Carpentry 6 01-18-2009 11:12 PM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 05:54 AM
