Stair Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 05:00 PM   #1
Rewards Points: 154
Stair construction
I'm building my first set of stairs, from an upper deck platform to a lower. It will be 14ft long, 36" wide, using four 2x12s. I plan to leave the outer stringers unnotched and attach the treads using metal brackets. The two inner stringers will be notched.
My reasoning is:
1. This will leave the outer stringers stronger.
2. It will weather better with fewer cut surfaces
3. The placement of railing posts will be easier and allow more flexibility.
However most of the stairs I see in my neighborhood have notched outer stringers. Am I missing something?
ovahimba is offline   Reply With Quote
Old 07-22-2010, 05:18 PM   #2
the Musigician
DangerMouse's Avatar
Most people prefer them that way because of sweeping and snow removal.
DM
Old 07-23-2010, 07:27 AM   #3
Old School
Willie T's Avatar
The Mouse is right. For the most part, the wind will keep the stairs clean of leaves and debris if the ends are open. Also, trapped, wet leaves in the corners are not only slippery, but can begin mold (rot).
I'm always curious when I hear of extra stringers on a narrow stairway like yours. Why?
You do realize that the weight carrying is handled by the thickness of the treads and support of the risers under the nosing edge of the treads, right? After a stringer is notched, in essence, all you really have left is little more than an angled 2x4. The code demands 5" left, but it would shock you how many are cut down to a lot less. (Not to scare you, though, most stair stringers cut from 2x12's have over 5 1/2" of good wood left.)
Willie T
Old 07-23-2010, 08:48 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
Stairs should be framed like everything else and you should always go 16" on center hence the need for the 4 stringers. This is especially true when it comes to composites as they are much more flexible. cut-out stringers are more common than what you intend to do. In addition to what has been listed above, there are a few more reasons. The un-notched stinger do not look as professional as the all open( notched) stringer look. Also, once you have your 1st pattern made it is easy enough to make all 4 the same and assembly is a breeze. no need for cleats or brackets.
Millertyme is offline   Reply With Quote
Old 07-23-2010, 08:51 PM   #5
Rewards Points: 154
Thanks for the responses
No, I didn't realize the primary strength of a stairway came from treads and risers tied together.
I assumed adding a middle stringer strengthened the structure. I figured adding two would double that effect. I thought it more of a consideration since the stringers are 14 feet long. If it were only 5 feet I wouldn't have considered more than one middle stringer.
I wasn't planning to have risers, to leave a more open look. As it is I probably need some sort of support in the middle of the span.
Old 07-23-2010, 09:04 PM   #6
Old School
Willie T's Avatar
The "more the better" theory on stringers comes from the sad loss of true construction knowledge and skills prevalent with modern day "carpenters".
Click here for dozens and dozens of examples of stairs constructed by people who still understand the basics of sound stairway construction.
Interestingly enough, if you research old stairs, you will rarely find any with more than two stringers. And they have stood the test of often hundreds of years of use.
BTW, that site is a clean architectural and design site called 'STAIR p-o-r-n'.org. Your browser may refuse to take you there. Google those two words (with or without the dashes) and you will find the most amazing stairs built in this entire world. No P_O_R_N involved at all.
Willie T
Old 07-23-2010, 09:11 PM   #7
Electrician
Proby's Avatar
Originally Posted by Willie T View Post
After a stringer is notched, in essence, all you really have left is an angled 2x4.
That's what I've always wondered. A stringer with un-notched treads is a 2X12 while notched treads is more like a 2X4 like you said. How does that have enough support? Isn't every notch a weak spot?
I know it's done, but I am wondering the science behind it. You mentioned the treads and risers tied together gives support, but what about when there are no risers?
BTW, your link was edited out by the forum software, the second part of the URL must be a banned word.
EDIT: the banned word is "p0rn", when someone clicks the link they can just replace the "****" with the correct spelling of the word p0rn. I've never seen that word itself censored out before, very odd.
Proby is offline   Reply With Quote
Old 07-23-2010, 09:18 PM   #8
Old School
Willie T's Avatar
Thicker treads. Treads are often 3" thick for this very reason. The 3" treads also let you pass the 4" 'ball passage' code requirements if the rise is kept to just under 7". This is for open treads with no riser boards.
As for the notches weakening a stringer.... see how many carpenters have the nerve to stand in the middle of a bare 8' notched stringer and bounce up and down. They know better.
See the added text above to deal with the banned site problem. It's really a site worth seeing.
Willie T
Old 07-23-2010, 09:50 PM   #9
Registered User
Rewards Points: 526
The 2006 Deck Code (which you may be under, check with local B.D.) requires a solid riser if at or over 4” high: Fig. 27
5” minimum of meat left after notching: Fig. 28
7’ max. span for cut stringers with SP.
16’6” max. span with closed stringers, SP.
Notice Fig. 29 and Table 6, also.
http://www.lancova.com/deckinfo.pdf
Be safe, Gary
Old 07-23-2010, 10:45 PM   #10
Old School
Willie T's Avatar
For your viewing pleasure, here is a stairway from that website that uses NO stringers whatsoever.
And they have many, many others that have even less apparent support than this one does. Please get to that site. The hundreds of beautiful stairs will WOW you.
Willie T
Old 07-25-2010, 11:41 AM   #11
SNC
For 36" threee stringers is enough 14' is not that long, more stringers is ok I get a lot of jobs where the engineer calls for 2x6 nailed 6" oc on both sides of the center stringer and one on each side of the outer ones.
SNC is offline   Reply With Quote
Old 07-25-2010, 06:11 PM   #12
Old School
Willie T's Avatar
As I will keep reiterating, a 36" stairway needs no more than a stringer on each side. Just a total of two. Why in the world would an engineer call for doubly reinforcing a center stringer if it did much good in the first place?
Go to the website listed, or simply look at the picture I've included (there are hundreds more on that website) and you will see that it is NOT multiple stringers that give the stairway its strength.
Do quit viewing this as though using the band-aid approach of adding pounds and pounds of nearly useless stringers is going to fix anything. Study a little, and learn what stair building is all about.
Willie T
Old 07-25-2010, 06:26 PM   #13
kwikfishron's Avatar
Rewards Points: 774
Wow, hope OP isn’t using Trex for his deck stair treads.
kwikfishron is offline   Reply With Quote
Old 07-25-2010, 06:28 PM   #14
Old School
Willie T's Avatar
I hope NO idiot uses Trex for much of anything.
THIS PHOTO will show you the ultimate importance of stringers.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
kwikfishron (07-25-2010)
Old 07-25-2010, 06:45 PM   #15
SNC
We do it all the time in apartment buildings and assited living buildings. Our stairs are not 36"
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 05:54 PM
Lighting for stair risers jweiner Electrical 2 04-06-2009 05:18 AM
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 01:47 PM
Stair framing question stubborn1 Carpentry 6 01-18-2009 11:12 PM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 05:54 AM
