Stair Calculations - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-30-2012, 08:21 AM   #1
Rewards Points: 160
Stair Calculations
I'm building a new set of exterior entrance basement stairs to replace a rotted out set. The total run/area to cover is 65 inches, and the height is 72 inches. Very steep, but it's all I have to work with.
Doing the math, I get 10 risers, 7.2 inches rise height, and 9 treads of 7.22 inches.
Since a 1x8 or 2x8 is 7.25" cut, can I round these both up to 7.25" (essentially making a perfect 1/2 square)?
Is a railing also required? It could only go part way up due to bilco doors folding over the stairs.
Also, the area under the stairs occasionally gets a little standing water, is there anything I can put under the bottom of the stringers to protect them?
matt151617 is offline   Reply With Quote
Old 06-30-2012, 08:31 AM   #2
Newly Retired
tuchodi's Avatar
Depends on what your building codes allow. I would make the treads wider if you can as 7.25" is very narrow and a wider step makes for more comfort when you use them.
tuchodi is offline   Reply With Quote
Old 06-30-2012, 08:45 AM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
An 8" rise and an 8-1/8" run would be better...that's 9 risers and 8 treads
Millertyme is offline   Reply With Quote
Old 06-30-2012, 08:48 AM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Can you post a picture? Maybe our collective mind can come up with a better solution to give you tread depth that is closer to code.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 06-30-2012, 08:49 AM   #5
Rewards Points: 160
I could also do 8 risers and 7 treads... 9" rise height and 9.29" run. So a 1x10 riser would need 1/4" cut off, and a 2x10 tread would have a 1.04" overhang. Is that too much?
I can get a picture later today but the broken stairs are still in the way. It's just an exterior basement entrance, made of concrete.
I'm not sure if this is subject to standard staircase code, it may qualify as an emergency or utility exit, since it's an unfinished basement, that has another staircase from the house.
Old 06-30-2012, 08:50 AM   #6
Civil Engineer
Rewards Points: 4,854
Typical code minimum is 11 inches for tread. Codes vary a little from place to place. I don't think you can build a code compliant staircase given the geometry you describe, which raises a number of difficult questions, such as future saleability of the house. I would discuss the issue with your building inspector, perhaps replacement of an existing staircase allows grandfathered geometry.
Old 06-30-2012, 10:31 AM   #7
MarginallyQualified
Rewards Points: 2,464
Get a shovel (or backhoe). Do it right.
Repair Stair Stringer sunshine54 Flooring 2 11-27-2011 11:06 PM
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 05:54 PM
Stair Nose Attachment - HELP! BSponz1 Building & Construction 2 01-11-2011 07:51 AM
Stair Nose Attachment - HELP! BSponz1 Flooring 3 01-10-2011 01:31 PM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
