Staining Treads, Painting Risers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-10-2008, 09:18 AM   #1
Staining treads, painting risers
I'm thinking of staining our basement stairs instead of installing carpeting. The treads appear to be a stainable grade of wood, but the risers are not. I would like to use wood with a smoother finish for the risers also. What do people normally do to correct this? Should I cover them with veneer, cut new risers from birch plywood?
QueenL is offline   Reply With Quote
Old 04-10-2008, 10:20 PM   #2
cover with 1/4 inch luan and paint{ cut to size, then paint , then install )
jason h is offline   Reply With Quote
Old 04-11-2008, 05:01 PM   #3
how do I attach it? Glue?? finishing nails??
Old 04-11-2008, 06:14 PM   #4
use a thin bead of construction adhesive and a couple small finish nails. fill nail holes then touch up paint.
Old 04-11-2008, 10:49 PM   #5
remodeling pro
Better off with 1/4" birch ply. Not only does the face not damage as easily as laun, it paints much better since it does not have the big open grain pattern of the laun.
troubleseeker is offline   Reply With Quote
Old 04-13-2008, 10:23 PM   #6
Registered User
Termite's Avatar
They're oak treads I imagine, why not use some 1/4" oak plywood to cover the risers so you can stain everything!
staining and painting window grids daveirwin Painting 3 04-12-2015 03:05 PM
Hardi plank - staining vs painting acdrey Building & Construction 36 03-22-2015 11:53 AM
Pennsylvania Bluestone Treads rjordan392 Building & Construction 4 03-30-2008 11:37 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 03:33 PM
Staining or Painting a New Fiberglass Door MelindaA Painting 1 12-31-2005 10:37 PM
