Staggering Hardiplank Joints - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-30-2008, 01:21 AM   #1
Soon my garage remodel will be back in full swing afetr the winter off. The south and west sides have been reframed after replacing the top plate,windows and door in,trimmed and aluminum wrapped,hardiplanked and caulked.Looks great. The next step is the north gable end. This wall is 24' long,which is great no waste on the 12' hardiplank. The only shame is that I'll have to cut up the 12' pieces in order to stagger joints, I guess into four,sixes an eights, and have a pattern repeat every third or fourth row. Right? Any advice or suggestions ( that means you,Atlantic ) would be appreciated.
white29 is offline   Reply With Quote
Old 04-30-2008, 06:17 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
The fact that you have to cut up the boards to create staggered lengths is not really going to waste all that much stock. In fact, when you purchase flooring, it is shipped in random lengths for the same reason.
Here is a pretty thorough discussion that answers your question:
http://www.helium.com/items/814835-c...tiful-addition
Go to the last several paragraphs. There's further discussion in the overall article that you should review as well.
Good Luck.
- Build Well -
Old 04-30-2008, 06:48 AM   #3
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
Good Luck.
Besides, you do have some sort of trim board on the os corners that will take up several inches. That will put your length down to 23'5" if you are using 5/4x4 and 23'1" if you are using 5/4x6.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 04-30-2008, 10:06 AM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,346
I'm not an experienced siding guy, but I've been placing my courses like a typewritter. Bring the cut off portion of the right side and use as the first piece on left side. I only keep the pieces that are at least 3 ft long.
This method, however, won't give you any pattern. I don't know which is more pleasing to the eye.
Almost, you forgot to add an inch on each side for the miter or cornerboard overlap.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 05-01-2008, 02:55 PM   #5
Thanks for the responses, and the article,Atlantic. I think I have a good idea how to go about this now. Another thing that I wasn't thinking about before is that I'll have two windows and a door that will break up the joints too.
hardiplank staining Katherine Painting 11 06-25-2012 02:08 PM
Replacing T-111 with Hardiplank BIOA Building & Construction 23 02-18-2008 09:07 AM
Nails for hardiplank white29 Building & Construction 4 09-27-2007 09:49 PM
