Staggering Exisiting Cabinets - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-11-2011, 06:12 PM   #1
Staggering exisiting Cabinets
I Want to stagger my existing kitchen cabinets. The are flush. So they will all be the same depth. I want to raise 3 of them to give them a staggered look. I realize the crown will need adjusting but does anyone have any opinions? Advice?
Kjm25bball is offline   Reply With Quote
Old 10-11-2011, 06:27 PM   #2
DIY staff
Rewards Points: 7,174
Which ones--typically the 'raised' cabinets are actually taller than the surrounding cabinets.
I do like the look of raised or staggered cabinets ,but I wonder about the look when the bottoms won't match.
Old 10-11-2011, 06:34 PM   #3
Military Mom of 4
Snav's Avatar
What a huge space!
Personally - I'd build decorative shelving that would nest right into the entire area - items can still be on display and maybe some more cabinets can fit.
To stagger existing cabinets you'd have to remove the ones you'd like the relocate - locate the studs above them - and reattach. Then stain, paint or cover the newly visible sides, cut old trim or new trim to fit.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 10-11-2011, 07:00 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
I think it breaks the monotony......
This is what we did with ours.....but then again, I made my own....
Old 10-11-2011, 07:38 PM   #5
So the cabinet above your refrigerator is not flush on the bottom with the cabinet next to it?
Old 10-11-2011, 09:10 PM   #6
When staggering cabinets the correct way, while using crown molding is anytime you bump up you must bump out.. So the crown molding has somewhere to end into flush.. I've seen it done without bumping out, but personally doesnt look right...
I would suggest bumping up and out ( making the cabinets 15" deep) the micro and fridge cabinets.. Use reguler framing to create the bump outs and purchases some 1/4" skins from the cabinet supplier ( make sure they are 15" deep, at least ) and run them along side of the cabinets to hide the framing you created to make the cabinets apear like they are 15" deep... You will also need more crown molding since you will now be creating 3 15"+ returns...
shillins24 is offline   Reply With Quote
Old 10-11-2011, 09:22 PM   #7
JOATMON
ddawg16's Avatar
Correct....see below....for that reason......
Additionally, that cabinet above the fridge is adjustable in height....and has in fact already been raised....we have a new fridge that is a lot bigger....so I raised it....
If you don't have the ability to make your own...then that is the way to do it.....
For reference....the cabinet with the oven in it...is 24" deep...the rest of them are 19" or 12" deep.
I'm not fast...but woodworking is good mental relaxation for me....
Old 10-14-2011, 09:29 AM   #8
Dee
SmallHouseLife's Avatar
Location: Texas! I wasn't born here but got here as fast as I could.
Image w/ example of raised cabinets
Hi Kim.. We frequently do the 'raised cabinets', as you're asking about, when we build new homes.
I've included a picture to show you.
I'm not sure what you mean by raising the cabinets to get staggering effect? If you do that, then the bottom isn't even.
Or maybe you meant you'll replace the cabinets with higher cabinets as we've done in this picture? ...which is very simple, btw!
dee
SmallHouseLife is offline   Reply With Quote
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 06:14 PM
Refinishing old Cabinets ryanb4614 Carpentry 4 08-18-2011 06:24 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
How are the premade HD and Lowes Cabinets? twilightcall Carpentry 10 05-25-2008 10:23 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
