Square Feet - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2007, 02:32 PM   #1
Rewards Points: 150
Square Feet
I have a room I need to insultate. It is 40x30. How do I figure out how many square feet I need?
econdave is offline   Reply With Quote
Old 02-06-2007, 02:45 PM   #2
Rewards Points: 1,232
Take the exterior walls, say that one 40' and one 30' wall are exterior. That is 70'. Multiply that by the wall height for the required SqFt of insulation.
Tscarborough is offline   Reply With Quote
Old 02-06-2007, 03:12 PM   #3
concretemasonry's Avatar
Rewards Points: 2,626
For the ceiling you need 1200 square feet.
If did that without taking off my shoes and counting on my square feet - LOL!
concretemasonry is online now   Reply With Quote
Old 02-06-2007, 05:02 PM   #4
Rewards Points: 150
Square Feet
if I take 40 +30 =70 x 10 feet high walls that would be 700 sq. wouldnt i need 1400 sq to cover the whole room?
Old 02-06-2007, 05:39 PM   #5
Rewards Points: 150
you got it... sqft area = length * height of each surface, just add 'em up.
1400 sqft for the walls
1200 sqft for the ceiling (if needed)
elementx440 is offline   Reply With Quote
Old 02-06-2007, 09:37 PM   #6
You only need to insulate the exterior walls. If they are all exterior walls, you don't have a room, you have a house.
Old 02-07-2007, 11:45 AM   #7
Long-Time DIYer
Mike Swearingen's Avatar
Square Feet = Height' (or Length') X Width' X Toes and all insulation vapor barrier goes toward heated space.
Mike
Mike Swearingen is offline   Reply With Quote
Addition "shell" cost per square foot - is this reasonable? ourzoo Building & Construction 21 12-20-2011 05:22 PM
lowering ceiling to 8 feet level mirico Carpentry 4 10-24-2009 08:24 AM
Purpose of square black washer on outlet cover screws? darsunt Electrical 3 07-20-2007 10:27 PM
Ridge vent question dpreznik Roofing/Siding 7 04-13-2007 03:03 PM
