Spring Metal Weathestripping Problem - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 05:29 PM   #1
I replaced some worn out spring metal weatherstripping around a door a while back. The new weatherstripping came rolled up, which resulted in it being wavy after it was straightened out and installed. The pictures I've attached illustrate the problem and how light comes through the gaps created by the waviness.
The weather stripping I replaced didn't have this problem. Can it be bought in long pieces that aren't rolled up, or is there a trick to installing the rolled up stuff?
I appreciate any advice on how to fix this.
Spring Metal Weathestripping Problem-lightws.jpg   Spring Metal Weathestripping Problem-wavyws.jpg
Major Pane is offline   Reply With Quote
Old 09-23-2010, 06:39 PM   #2
Retired from the grind
Rewards Points: 6,652
Yes, you can get aluminum weatherstripping, that is more durable, and has a better sealing gasket, than that crap you bought.
Old 09-24-2010, 08:02 AM   #3
Rewards Points: 5,336
You can also use a compression weathstripping that will seal the door better.
If you have a little patience, you can simple bend the problem areas so it seals the door. That's the good thing about metal, its malleable.
Ron
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Need help solving spring basement flooding problem prairiedoggy Building & Construction 19 05-24-2010 10:59 AM
Hardwood and Metal Post Problem! moonweb Flooring 13 07-02-2008 03:12 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Spring Hinges jb198606 General DIY Discussions 3 02-06-2006 08:40 PM
