As long as it's not on OSB;
Practical Recommendations
• When using medium-density (MD) foam
in walls as both insulation and vapour
barrier, a minimum thickness of 40 mm
is recommended.
• When placing a foam product in an
exterior wall assembly, ensure that the
moisture flowing through the foam will
not affect other materials. This could
happen when moisture is trapped in a
moisture-sensitive material, such as
plywood or OSB, and drying is prevented
by the layer of SPF.
http://www.earthane.com/ctu32e.pdf
http://www.buildingscience.com/docum...d%20in%20walls
Gary
Clothes taking longer to dry?
