Spray Foam Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2009, 08:05 PM   #1
spray foam insulation
I have a unfinished basement , i am going to frame the walls (2x4) and i,m wieghing my options for insulating i know about the rigid foam and batt insulation method - i want some input on the enviro spray foam method -seems like it would be the easiest but most costly(we,ll say money is no object- especially when you got none) - was wondering anyones expirence doing this and the cost is I live in nova scotia
jdgeorge is offline   Reply With Quote
Old 03-24-2009, 03:53 PM   #2
Check out the brands thouroughly. CDN Government just put a hold on Retrofoam, distributed here and across Canada
Chemist1961 is offline   Reply With Quote
Old 03-24-2009, 05:15 PM   #3
Remodeling Contractor
spray foam is better in every way for basements. Closed-cell has twice the R-Value as Open-Cell. But Open cell will allow the walls to still transfer moisture without trapping it in the wall.
Spray foam insulation troyce1 Insulation 12 12-14-2014 06:30 AM
spray foam insulation mikeybobo Building & Construction 11 06-19-2010 04:04 PM
spray foam insulation MikeyP Building & Construction 3 01-25-2009 02:48 PM
Air cavity required behind spray foam roof insulation BigJimmy Building & Construction 9 06-08-2008 12:45 PM
