Old 07-11-2011, 07:27 AM   #1
Spray Foam Installation Problems
As if the spray foam industry didn't already have a dubious history with urea formaldahyde foam.
Spray foam ignition
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
gma2rjc (07-11-2011)
Old 07-11-2011, 08:39 AM   #2
Super Moderator
Interesting read. This is the first I've ever heard of the problem. Foam is still a very expensive process and I have not used it my self.
Old 07-11-2011, 09:35 AM   #3
Do plumbers and electricians hate this stuff from a remodeling stand point, you would have to open every wall you needed to go through, right.
josall is offline   Reply With Quote
Old 07-11-2011, 09:47 AM   #4
Thanks for posting that article Ron.
gma2rjc is offline   Reply With Quote
Old 07-11-2011, 12:40 PM   #5
Architectural Designer
AGWhitehouse's Avatar
Due to the combustible nature of the product, the new IBC requires all spray foam to be covered with a thermal barrier (gwb, plywood, etc.) even in attics and crawl spaces.
Josall, I don't like specifying the stuff for that reason. I can't imagine what it would cost to carve all this stuff out for some simple re-wiring.
AGWhitehouse is offline   Reply With Quote
The Following User Says Thank You to AGWhitehouse For This Useful Post:
josall (07-11-2011)
Old 07-11-2011, 01:49 PM   #6
This foam ignited during the application process.
Ron
B. Franklin 1759
Old 07-11-2011, 01:53 PM   #7
Yep, just wanted to FYI that tid-bit to further that foam is combustible before installation, during installation, and after installation.
Old 07-11-2011, 02:50 PM   #8
When I was spraying Foam It Green up into my soffits last fall, I could feel the heat coming off the foam as it was setting up. It wasn't an intense heat, but it was toasty warm.
Great Stuff spray foam option eend Insulation 5 03-21-2011 03:00 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Is spray foam insulation that much better than fiberglass? HautingLu General Discussion 18 09-21-2010 07:36 PM
spray foam insulation mikeybobo Building & Construction 11 06-19-2010 05:04 PM
spray foam insulation MikeyP Building & Construction 3 01-25-2009 03:48 PM
