-   -   Spray Foam Installation Problems (http://www.diychatroom.com/f19/spray-foam-installation-problems-110349/)
Ron6519 07-11-2011 07:27 AM
As if the spray foam industry didn't already have a dubious history with urea formaldahyde foam.
Spray foam ignition
oh'mike 07-11-2011 08:39 AM
Interesting read. This is the first I've ever heard of the problem. Foam is still a very expensive process and I have not used it my self.
josall 07-11-2011 09:35 AM
Do plumbers and electricians hate this stuff from a remodeling stand point, you would have to open every wall you needed to go through, right.
gma2rjc 07-11-2011 09:47 AM
Thanks for posting that article Ron.
AGWhitehouse 07-11-2011 12:40 PM
Due to the combustible nature of the product, the new IBC requires all spray foam to be covered with a thermal barrier (gwb, plywood, etc.) even in attics and crawl spaces.
Josall, I don't like specifying the stuff for that reason. I can't imagine what it would cost to carve all this stuff out for some simple re-wiring.
Ron6519 07-11-2011 01:49 PM
This foam ignited during the application process.
AGWhitehouse 07-11-2011 01:53 PM
Yep, just wanted to FYI that tid-bit to further that foam is combustible before installation, during installation, and after installation.
gma2rjc 07-11-2011 02:50 PM
When I was spraying Foam It Green up into my soffits last fall, I could feel the heat coming off the foam as it was setting up. It wasn't an intense heat, but it was toasty warm.
