Old 05-03-2010, 04:05 AM   #1
Spray foam - code issues?
Anyone aware of any code issues with using spray foam in the walls with reference to both house and low voltage wiring & plumbing as well? I thought I had read somewhere about possible heat issues with the house wiring and interference with the low voltage wiring. Don't know about plumbing issues.
If there are any known issues with it - can I run the wiring across the (truss) joists and then down the wall in conduit?
Thanks,
Rick
upinsmoke is offline   Reply With Quote
Old 05-10-2010, 08:47 PM   #2
The wires are fine to spray around. The only thing is the manufacturer of the recessed lights want you to wrap them in fiberglass batts and then spray up to the batts or box them in. That is all I was told
bfan781 is offline   Reply With Quote
Spray foam insulation troyce1 Building & Construction 9 05-24-2011 07:57 PM
Diy spray foam insualtion kits ?? What have I done Building & Construction 3 12-14-2009 09:20 AM
Touch n' Foam (spray) 'Pro System' - good product? KatieAK Building & Construction 0 11-19-2009 07:59 PM
Is Spray Foam insulations guaranteed? shanemcguire1 Roofing 3 04-03-2009 04:53 AM
Spray foam insulating ceiling under flat roof Jed Lukewater Remodeling 1 01-12-2009 08:22 AM
