Spray Foam Around Windows/doors - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-09-2013, 08:17 AM   #16
bbo
I think you guys are talking about two different things.
Kirk, you are talking about if the cavity gets overfilled and using a demo blade to get inside the cavity to remove material so the jamb/window opening can retract back to normal, right?
and Bill, you are talking about trimming excess foam outside the cavity of the window/door, right?
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
woodworkbykirk (08-09-2013)
Old 08-09-2013, 08:36 AM   #17
Bill Kearney
Rewards Points: 1,174
Yeah, I'm talking about excess foam that's protruding out beyond the level plane of the framing. Not trying to dig out into a cavity that's been overfilled with the wrong kind of foam; putting pressure on the window sashes and keeping them from opening smoothly. For that you'd likely want a pretty stiff and aggressive tool.
But I've found saws don't really do a great job of pulling any depth of foam away. For that I found it was better to use a wrecking pry bar to dig it out in chunks. Either the typical 18" size or a smaller one with a cats paw end typically used to get at embedded nails. Tedious but more accurate and less prone to coincidental damage than a recip. saw.
wkearney99 is offline   Reply With Quote
Old 08-09-2013, 09:57 AM   #18
Rewards Points: 154
Here are some more tips
When using the foam I cover the edges of the window, sheetrock or any trim with painters tape. Take it off only when it is fully set after an hour.
To cut off excess, I prefer just a few easy strokes with a steak knife. Anything larger or without serrations tends to just tear the stuff.
Forget trying to save half used cans by jamming a screw or stick in the nozzle. Just place the nozzle, trigger and top of the can in a ziplock bag with a little acetone. Swish around the parts until completely clean and dry on paper towel. I have been able to use one can half dozen times doing this.
ovahimba is offline   Reply With Quote
Old 08-09-2013, 10:03 AM   #19
Bill Kearney
Ah, nice tip about the bag and acetone. I'll have to try that next time.
Old 08-09-2013, 11:55 AM   #20
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 962
Originally Posted by Ron6519 View Post
The issues you describe are ones that occur when the wrong foam is used by people who don't know what they're doing.
Ron
Ha. This is me a few years back on my first window install. The slider is tight to this day.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 08-09-2013, 12:49 PM   #21
If anyone does a fair amount of remodeling, do yourself a favor and get a Hilti foam gun.
The valve is in the metal tip, so you don't have to use the whole can at one time.
For cutting the foam I like a Japanese hand saw...just my preference.
RoyalAcresRod is offline   Reply With Quote
Old 08-09-2013, 02:48 PM   #22
DAP makes one that cleans up with soap and water. I've only used it to make a zombie piņata so I don't know how well it insulates.
You could tell which window I started with when I spray foamed our house (once the trim went on, it looked fine). Be sure to follow what the others said about only filling a little and letting the expansion do the rest. Wear gloves, that stuff is sticky, hard to remove from skin and uncomfortable to wear until you outgrow that particular patch of skin. Seriously, I'd rather deal with super glue exploding on my hands. Also, I wish I'd known that tip about using painter's tape. I still have to fix this farkakt piece of work.
Spray foam around windows/doors-image-3007831545.jpg
Don't drink and foam people.
MissKat is offline   Reply With Quote
Old 08-09-2013, 05:13 PM   #23
123pugsy's Avatar
Rewards Points: 962
No worries. I prefer to foam animals rather than people.
Old 08-09-2013, 06:41 PM   #24
Hah! Not the worst dropped comma I've seen but that's what I get for hitting send, then editing.
Old 08-09-2013, 07:12 PM   #25
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,116
yes, in regards to getting the foam out of the cavity in order to draw the window or door back so it operates
as for the water based foam.. i dont trust it.. if the window sweats whats stopping the condensation from breaking down the foam thus losing your insulation in the cavity over time.. as it breaks down it creates more air space allowing more warm moisture laden air in there which can then lead to rot
woodworkbykirk is offline   Reply With Quote
Old 08-11-2013, 07:50 PM   #26
Registered User
Rewards Points: 5,492
http://books.google.com/books?id=a29...995%29&f=false
Gary
Spray foam insulation troyce1 Insulation 12 12-14-2014 06:30 AM
spray foam insulation mikeybobo Building & Construction 11 06-19-2010 04:04 PM
spray foam - headers and flat ceiling biglumber35 Building & Construction 2 05-01-2009 11:40 PM
spray foam insulation MikeyP Building & Construction 3 01-25-2009 02:48 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
