Old 10-12-2009, 10:57 AM   #1
Default Spray foam around windows/doors
I picked up some of the "Great Stuff" spray foam formulated for use around (roughed in) windows and doors. Has anyone used this product for this use? I have heard a lot of nightmare stories about doors not closing as the foam expanded and the like. It sure would be be faster and easier than stuffing insulation around the windows and doors. I have nine rough openings to do in my garage converted to living space. Thanks.
white29 is offline   Reply With Quote
Old 10-12-2009, 11:09 AM   #2
The issues you describe are ones that occur when the wrong foam is used by people who don't know what they're doing.
The correct foam will be fine, just don't overfill the space.
Ron
Old 10-12-2009, 11:10 AM   #3
Civil Engineer
Great Stuff makes at least three different foam formulations, one of them is for small cracks, one is for large cracks, and one is for windows and doors. The difference is that the windows and doors formulation does not expand nearly as much as the other two, hence is not as likely to bow out your jambs. Make sure you use the correct formulation. I have used it for several doors in exactly the way you intend, no problems. I have also used thesmall crack formula to insulate against the rim joist, and it seems to exert a large amount or pressure, and would almost certainly be big trouble in a door or window application, but I have not done the experiment.
Old 10-12-2009, 11:49 AM   #4
I have used "Great Stuff" for many projects. I always try to keep a couple of cans around. If you are using it in a particularly dry climate or when the humidity is low you need to mist the area with a little water before applying the foam to get the fastest cure time. It seems (at least to me) the quicker it expands the less pressure it exerts on the materials you are applying it to as long as it has somewhere to go. I always lightly mist the area with a spray bottle of water, just enough to make the material damp. This also help the foam adhere to dusty or dirty material.
Rege
RegeSullivan is offline   Reply With Quote
Old 10-12-2009, 09:36 PM   #5
Get the one that has minimal expansion after initial application - saves bending things.
Old 10-15-2009, 04:24 PM   #6
Drywall contractor
What "vsheetz" said, if you want your windows and doors to function properly. It's really not that tough to "chink" the spaces with regular fiberglass insulation. You probably have scraps left over......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-15-2009, 05:52 PM   #7
Household Handyman
For the "For What It Is Worth" department: I just returned from a five week stay in Fairbanks, Alaska. My daughter bought another home, built in '76, and it needed a few minor things done to it. And Yes! I certainly wanted to visit my daughter and grandson. While I was there I was asked to replace an older door unit with a new, energy efficient type. There were some contractors working on a home in the area, so I went over and asked them about particulars of installing doors in this area. One thing I was told, it is code in Fairbanks to use an expanding foam between the door frame and rough-in, no loose/fiberglass insulation is allowed. The door project went well. The non-expanding GreatFoam was used, the door frame did not move, and all is well. I learned valuable lesson on having different codes for different parts of this country, and a new experience replacing an exterior door in 27º weather.
Thanks, David
More On This Topic
Hi, this is Jon and in this clip we will be filling our gaps. If we take a look at the inside of our door, we do have some gaps that we need to fill so that we don't get any air coming through there. To fill our gaps we are going to be using a spray... Read More »
Whether you are buying an exterior door for a new construction or you want to replace an older door, it is important to remember that the exterior doors of your home are the first impressions that are made upon your guest. Buying an exterior door is... Read More »
One area where homes are less energy efficient is around doors. Many older doors leak around their edges, and many others are simply not insulated enough to provide good energy efficiency. Making doors energy efficient is one of the most obvious ways to... Read More »
Everyone knows to close the door behind them in the winter. But sometimes that isn't enough. General wear and tear on your door can create gaps that let cold air in and cost you money. Fixing these is relatively easy, and a little time and money spent to... Read More »
Okay now we are going to do the door frame, still using the number ten brush and we are going to do this window frame up here too. It is a little thicker than the door frame and we are going to add a little bit of red to it, so we get an orangier version... Read More »
Spray foam insulation troyce1 Building & Construction 6 09-10-2009 01:02 PM
spray foam - headers and flat ceiling biglumber35 Building & Construction 2 05-02-2009 01:40 AM
spray foam insulation MikeyP Building & Construction 3 01-25-2009 04:48 PM
spray foam insulation mikeybobo Building & Construction 9 01-05-2009 02:02 AM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing 2 09-19-2008 09:12 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
