Spray Foam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-23-2010, 11:29 AM   #1
spray foam
Need a little direction here:
2x8 ceiling joist in a bonus room above a garage, located in Michigan.
want the highest R-value without building ceiling down.
was looking at closed cell spray foam.
--will 2 pound density break away over time (to rigid?)
--should i get 1/2 pound density?
Should i do splash and dash?
-- or will that create 2 vapor barriers?
seems like everyone has their own idea on rafter baffles with spray foam!
-- what does the roof shingle manufacturers have to say?
any other ideas???
Thanks for your help in advanced.
newmanab is offline   Reply With Quote
Old 03-25-2010, 03:45 PM   #2
Rewards Points: 131
Newmanab, I had a similar question in relation to the best place to buy the foam. Where are you getting yours from?
HitLines is offline   Reply With Quote
Tags
spray foam
Spray foam insulation troyce1 Insulation 12 12-14-2014 06:30 AM
DIY spray foam kits HitLines Building & Construction 4 03-18-2010 12:58 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
spray foam - headers and flat ceiling biglumber35 Building & Construction 2 05-01-2009 11:40 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
