Spray Foam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-20-2013, 01:57 PM   #1
n2omichael's Avatar
Rewards Points: 115
Spray Foam
I bought one of those spray foam kits (600 board feet) that looks like 2 propane tanks, I am
Using it to seal up the sills on my new foundation.
It's starting to get chilly "up here" and I was wondering what the minimum temperature is to spray the foam? The building is closed in, but not heated, I do have a couple of propane heaters I can use to bring up the temp if need be.
All input appreciated!
Michael
n2omichael is offline   Reply With Quote
Old 10-20-2013, 02:23 PM   #2
kwikfishron's Avatar
Rewards Points: 824
What's manufacturer say? Go to their website and look at the product data sheet. That will tell you everything you want to know and more.
kwikfishron is online now   Reply With Quote
The Following 3 Users Say Thank You to kwikfishron For This Useful Post:
gregzoll (10-20-2013), Msradell (10-20-2013), woodworkbykirk (10-20-2013)
Old 10-21-2013, 07:21 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,274
They need to be at or near room temperature for a good while. Do not try to just quickly heat them via propane heaters.
Keep them inside a conditioned space for a solid day before using and then use them.
Old 10-21-2013, 12:59 PM   #4
n2omichael's Avatar
Rewards Points: 115
Thanks!
How about the temperature of the actual room I am spraying the foam in? Does it need to be "room temperature" as well?
Thanks for the input!
Michael
XPS Foam on uneven basement wall - Pt.2 (no spray foam) jefferyscott Building & Construction 17 01-04-2017 09:27 PM
Spray foam Question b lowell Insulation 4 01-30-2013 02:34 PM
Spray foam in attic diystephen HVAC 6 12-29-2012 01:07 PM
DIY spray foam ACR_SCOUT Insulation 12 12-30-2011 06:57 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
