Spray Foam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 04:11 PM   #1
Spray foam
I had a guy give me an estimate to spray foam my vaulted ceilings I put up baffles already for the air flow but he told me I do not need them. Is that right that I won't need air flow between foam n the roof? I thought u always need it
ecocco1469 is offline   Reply With Quote
Old 03-22-2013, 04:32 PM   #2
Rewards Points: 13,450
If it's foamed you do not need the baffles.
Old 03-25-2013, 08:49 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,086
+1
Joe is 100% right.
Just make sure they apply appropriate thicknesses.
Old 03-25-2013, 10:16 PM   #4
Registered User
Rewards Points: 5,482
If you live in a high snow area, you will need the venting rather than a "closed roof" to prevent ice dams. The design should be on the plans; if new build/addition, approved by the city/county. Simple gable roofs benefit from ventilation more than complex roof designs, or HVAC in the attic. Your location is important, where are you located?
Gary
PS. pp.3, vents with SPF: http://www.buildingscience.com/docum...n-roof-venting
Old 03-25-2013, 11:54 PM   #5
Rewards Points: 636
good article
http://www.jlconline.com/insulation/...pray-foam.aspx
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-26-2013, 03:27 PM   #6
Registered User
I reviewed your other posts, 1469, and had a question from this thread; Rafters
Are the "new rafters" bearing on a built-up (multiple pieces) or a solid beam (3-1/2"- 7-1/2" wide)at the top, OR are they bearing against each other with a new 2x board between them?
Not a ridge "board" as in "B", but a ridge "beam" as in "C", scroll down a page here; http://books.google.com/books?id=E5S...raming&f=false
Gary
PS. pp. 105, 106; http://books.google.com/books?id=s-x...thrust&f=false
Old 03-27-2013, 11:08 AM   #7
The one guy who came said he will put in 5 in of open cell foam between my rafters. I have a vaulted ceiling n my rafters r only 2 by 6 then I had another salesman who said he would put 3 in of closed cell foam in. He also said that 5 in of open cell could cause condensation n water spots n when I asked the first guy he said that it wouldn't b a problem. Who is telling me the truth? Anyone out there now anything about spray foam n what I should do for the vaulted ceiling with 2 by 6 rafters I'm tired of these salesman just telling me his product is better n there's no problem with what they want to put in
Old 03-27-2013, 12:21 PM   #8
Rewards Points: 626
Now are they rafters, or trusses? I would always error on the side of ventelation and do tradtional insulation or a BIB system. Foam to me is over rated and not cost effective, or the pay off is years down the road. Plus I am waiting to see these new home done with foam in the attic how fast the roofs need to be replaced as well. I have seen in the pacific north west some homes only ten years old with 50 year shingles being re roofed. from what cause I am not sure. But am willing to bet it has to do with ventilation or the lack there of for the underside of the roof.
Nailbags is offline   Reply With Quote
XPS Foam on uneven basement wall - Pt.2 (no spray foam) jefferyscott Building & Construction 17 01-04-2017 09:27 PM
Spray foam Question b lowell Insulation 4 01-30-2013 02:34 PM
Spray foam in attic diystephen HVAC 6 12-29-2012 01:07 PM
DIY spray foam ACR_SCOUT Insulation 12 12-30-2011 06:57 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
