Split Pocket Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 10:49 PM   #1
Split pocket door
I am wanting to add a pocket door to a room and I thought it would be cool if it were split in the middle and both halves opened away from each other. Not a new idea but what I was thinking is could I use a table slide equalizer as my track above the door? If it worked right when you pushed one door open the other door would open too. It would also help keeping my door centered when they were closed. I have never seen one of these slides in person so I dont know if I can mount it and hang a door off of it yet. I might get one so I can look at it and think some more.
http://www.watervillewoodcraft.com/EN/table.htm
Anyone done something like this? If it is going to be too much of a pain I will just do the normal door but this other way would be cool.
Justin8152000 is offline   Reply With Quote
Old 06-20-2011, 01:45 AM   #2
Rewards Points: 6,652
Why try to recreate an invention that is already perfected. They make kits for what you are wanting to do.
Old 06-20-2011, 04:54 AM   #3
Too Short? Cut it Again!
I think you are going to find the weight of your pocket doors to be an issue especially if spanning a large open space with something solid---glass, hardware, etc.
You might consult an architect on this. You would not need but a few hours time for one to detail out your install and help you locate the door.
Old 06-20-2011, 08:49 AM   #4
Rewards Points: 5,336
Table slides aren't engineered for this application. Use pocket door hardware.
Ron
B. Franklin 1759
Old 06-20-2011, 09:48 AM   #5
Rewards Points: 150
Hafele model HAWA 80/Z is the hardware set sold for just this application. Phone Hafele in NC for a quote 1-800-423-3531
josall is offline   Reply With Quote
Old 06-20-2011, 02:53 PM   #6
Great thanks guys! I deffently dont want to reinvent the wheel but I hadent found anything like that but I guess I havent looked in the right place.
Thanks again, I will post pictures when I start it.
Old 06-20-2011, 03:53 PM   #7
Look at Johnson Hardware, they also make a quality pocket door kit
Ron
B. Franklin 1759
hollow or solid core door for pocket door RobertN Building & Construction 4 10-12-2015 07:55 PM
pocket door help samuel11 Building & Construction 7 08-19-2010 02:44 PM
Repairing Split in Wood Door? diyintexas Carpentry 4 10-11-2009 01:00 AM
Considering Pocket Entry Door at top of stairs snsdiy Remodeling 6 01-06-2009 06:39 AM
Pocket door and tall floor...oh my wem Remodeling 3 03-24-2008 05:45 PM
