Splicing Beams - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-26-2012, 11:49 AM   #1
Splicing beams
If you are sandwiching beams to the post for a deck, where can you splice long beam runs and how? Beams are 2x10 and post are 4x4 and only about 12 above ground. I have about a 30 run with 5 post using 16 2x10s. Will need to splice does it have to be on a post, please explain all my options and how thank you all
tminer is offline   Reply With Quote
Old 11-26-2012, 11:53 AM   #2
joed's Avatar
Rewards Points: 13,308
Join then at a post and try not to join both side at the same post.
The Following User Says Thank You to joed For This Useful Post:
tminer (11-26-2012)
Old 11-26-2012, 07:41 PM   #3
Beam Layout
As I understand your spacing you will have (on any one beam run) 5 posts so they will divide the 30 foot run into 4 spaces. Therefore any space will be 7.5 feet. More important the center post will be 15 feet from either end. Perfect for 16 foot 2x10s. Lap your 2x10s at the center post and let the excess length extend a foot beyond the center post. No cutting required of the beams.
Budprine is offline   Reply With Quote
Old 11-26-2012, 08:55 PM   #4
Registered User
Rewards Points: 526
The post spacing depends on the species and load from joists; pp.5, Table 3; http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Gary
Old 11-26-2012, 09:09 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
joints can either be directly over the post or within the 1/4 points.. meaning that they must be within 1/4 of the span between posts.. if you have one 1/4 joint on one end start the next lam from that end to break up the joint
also.. why are you using a 4x4 for the post especially if its 12' high. in most regions all posts carrying a beam must be 6x6. 4x4's are only good for hand rail posts
woodworkbykirk is online now   Reply With Quote
Old 11-26-2012, 09:17 PM   #6
AHH, SPANS!!!
Rewards Points: 1,166
beam splices need to land on posts. If as Budprine suggests you have 7'.5" spacing between posts then set as a single section a fifteen foot 2x centered outward from the middle post and then fill the ends in. Next, set the other section(build the beam in two parts) so the splice lands on the center post. You want to have a minimum of 1 1/2" bearing at all bearing points...
hand drive is offline   Reply With Quote
PT beams warp or twist off posts? windowguy Building & Construction 5 09-06-2012 07:24 AM
Pergola Notched Cross Beams Are Bending and Warping dcunited122 Building & Construction 10 06-25-2012 06:20 AM
New posts and beams in crawlspace, post out of line WillK Building & Construction 1 02-26-2012 09:56 AM
Connecting Beams And Post JoeLena Building & Construction 5 01-01-2011 04:32 PM
hanging weight off of tji beams?? summer76 Building & Construction 2 04-14-2009 02:00 AM
