Spilt Candle Wax On Unfinished Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-29-2010, 06:50 PM   #1
.chris.'s Avatar
Spilt Candle Wax on Unfinished Deck
Hello all:
My wife accidentally spilt citronella candle wax on our deck. The deck is made of PT wood and has yet to be stained/finished. My question is: What is the best method for removing the wax so we can get to staining?
Thanks in advance!
EDIT: I actually tried searching the forums to avoid any duplicate threads. Unfortunately, the site won't let you search the word "wax."
.chris. is offline   Reply With Quote
Old 07-29-2010, 08:43 PM   #2
Rewards Points: 5,336
You can use paint thinner to dissolve wax. Remove any globs and use the thinner. Let it dry and sand the surface.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
.chris. (07-29-2010)
Old 07-29-2010, 11:15 PM   #3
.chris.'s Avatar
That simple? Wow...thanks!
Old 07-29-2010, 11:40 PM   #4
If you want easier just take out your clothes iron and put some paper towel over the wax. Iron the paper towel and it will soak up all the wax. Cleanup then becomes ridiculously easy and no sanding required.
Troglodyte is offline   Reply With Quote
The Following User Says Thank You to Troglodyte For This Useful Post:
.chris. (07-30-2010)
Tags
candle , deck , removal , staining , wax
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
